The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
20 members (3B, Cletus1950, EdPruss, Eureka Jim, Doc.Hall, 2 invisible), 155 guests, and 3 robots.
Forums60
Topics123,959
Posts1,000,366
Members44,791
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Signal switch assy
#1412466 Thu Jun 03 2021 11:52 AM
53&Me Offline OP
Hey all, does anybody out there know if there is a good source for an OE style blinker switch assy? I've been looking around and have had no luck with the findings old style or.... period period correct.
Re: Signal switch assy
53&Me #1412474 Thu Jun 03 2021 12:28 PM
AD Addict
Do a search for “vintage turn signal switch” on eBay and you will get both new and old, period correct switches for your ‘53. To my knowledge, the GM didn’t make them back then.
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
53&Me #1412475 Thu Jun 03 2021 12:39 PM
Look for a Guide 6004 turn signal switch. They were mounted to the steering column.
Phak1 #1412478 Thu Jun 03 2021 01:02 PM
53&Me Offline OP
Thanks Phak1, I'll give that a try.
fonz8261 #1412479 Thu Jun 03 2021 01:06 PM
53&Me Offline OP
Thank you as well fonz, that's a couple things to search out that I didn't have before. Definately a great community to be a part of.
53&Me #1412543 Thu Jun 03 2021 07:45 PM
Something you might try. The turn signal switch assembly for a 53-54 car is the same as used on 55-59 TF trucks. I think there is a good possibility it could be adapted to your 53 truck as well.
Fred
rfs56trk #1412607 Fri Jun 04 2021 10:23 AM
53&Me Offline OP
Thanks rfs56trk, I'll look into that, my '53 3/4 ton truck just had the wires hanging and no switch. when I pulled it out of it's grave.
53&Me #1412633 Fri Jun 04 2021 03:08 PM
The Truck Shop catalog shows a 54-56 switch and a 57-59 switch. Brothers has them also. The only difference would be the angle of the lever for the flat vs the dished wheel. You should be able to use the cancelling plate as well.
Fred
53&Me #1412690 Fri Jun 04 2021 09:30 PM
AD Addict
The ‘54 has a different steering wheel than the ‘53 and there was no option for signal lights in ‘53. I don’t know for sure but I think you would have to change the steering column to adapt the 54-55 signal switch.
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
53&Me #1412710 Sat Jun 05 2021 12:15 AM
Sir Searchalot
As said, there is no OE for trucks, but there is period correct. In 1953 cars, a "Factory optional Accessory" turn signal was available. Made by "Guide". Self cancelling. It was an integral unit blended into the steering wheel. Maybe one of those 1953 car units would work for a truck?...or from a 54 truck as Phil suggested.
The period correct column mount unit of choice for trucks would have been a Guide brand. Owned by GM. Self cancelling. Available at dealers. Accessory shops.
Several other brands were available elsewhere.
The guide unit would be similar to this.
Watch out for careful drivers!!!
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Sometimes no nonsense makes sense, in a sense.
You can't teach a new dog old tricks.
Honk if you're Amish
53&Me #1412745 Sat Jun 05 2021 04:09 AM
53&Me Offline OP
that's good stuff, In that case I think I will keep on digging and see what feels right
53&Me #1412749 Sat Jun 05 2021 05:48 AM
Follow these links to several pictures of a NOS 6004 kit, where part numbers are visible you can cross the applicable years.
https://www.flickr.com/photos/advance-design_parts_co/8129416019/in/album-72157631868452754/
53&Me #1412751 Sat Jun 05 2021 10:12 AM
I use electronic self cancelling turn signal switches from a Kawasaki motorcycle for $20 or you can buy an after market kit for $100. One of my cars has a right and left momentary button and the other has a return to center toggle switch on a column mounted stalk. A quick push and the signal blinks 11 times then shuts off. A one second push and it blinks 21 times and cancels. Impossible to forget signal is on. On the right-left button one if you push both buttons you have 4 way flashers till you manually cancel. They were used on motorcycles because you can't hear the clicking over the motor and can't see the indicator light(s) in bright sun light.
Evan
53&Me #1412904 Sun Jun 06 2021 09:38 PM
This is the restored Guide 6004 turn signal switch that I have in my '48 Chevy 1/2 ton truck.
53&Me #1413088 Tue Jun 08 2021 01:02 PM
53 and me Found a 7 wire guige at the junkyard.got a wiring diagram internet,wired it all-up crazy as could be !! Shot it with tuner cleaner worked fine after that. 7 wire interlocks your stop lights with turn signals,takes only 3 wires to the rear of the truck. Try e-bay, get tuner cleaner amazon or electronic repair like frey.
fonz8261 #1414094 Wed Jun 16 2021 06:38 PM
53&Me Offline OP
That's great! I'll look for one of those, thanks for the pictures
fixite7 #1414095 Wed Jun 16 2021 06:40 PM
53&Me Offline OP
I'm gonna look for that tuner cleaner, thanks for the info fixite7
Page 1 of 2 1 2
Moderated by  Rusty Rod
