The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (BCLEM, coilover, hardshell, Dusty53, carbking, 32vsnake), 149 guests, and 4 robots.
Forums60
Topics124,729
Posts1,006,726
Members45,019
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 3 of 3 1 2 3
Re: It's alive....53 3100, 216
Crowbar65 #1411239 Tue May 25 2021 12:41 AM
Congrats! The only better feeling is watching it MOVE ON ITS OWN POWER!! Keep goin'!
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
pan3lman #1411511 Thu May 27 2021 01:41 AM
That first ride clearly trumps the all be it awesome first start.
Crowbar65 #1413174 Tue Jun 08 2021 08:28 PM
"Water not stay in the radiator long enough to cool..." Old wive's tale. The racers up the flow rate as much as possible to reduce hot spots within the engine. I've run with no thermostat and it never got above 140. I run mine over the mountains (5600 ft.) in the summer and found the 180 is too hot. Engine is noisier when it's hotter. 160 seems just right. I no longer drive it in the winter because the state is now using de-icer on the roads so I just leave the 160 in year round.
51 3800 PU, 55 235 (w/cam, headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971.
1Ton_tommy #1413189 Tue Jun 08 2021 10:11 PM
A little math quickly dispels that notion. If your coolant flows slower through your radiator dissipating heat, it also flows slower through your block and heads, gaining heat. Your engine head temp is around 400 degrees, or 220 ABOVE the ideal engine coolant operating temperature of 180 degrees. Ambient air flowing through the radiator is approximately 80-100 degrees (depending on the weather), or 80 degrees LESS than the ideal engine coolant operating temperature. 220 degree gain versus 80 loss - the slower the coolant flows, the more it will heat up.
1951 Chevy Panel Truck
Page 3 of 3 1 2 3
Moderated by  Justhorsenround
