The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (Ashbourne Keith, coilover), 129 guests, and 2 robots.
Forums60
Topics125,051
Posts1,009,307
Members45,127
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Alternator Wires
#1411473 Wed May 26 2021 09:40 PM
I didn't take good notes when I pulled my 261 but I'd like some confirmation for the alternator when putting things back together.
In the picture, the white plug obviously gets plugged in and the heavier red wire gets attached to the only post on the alternator back. The other end of the heavier red is already on the junction block on the firewall.
Where does the smaller red wire that comes out of the plug go? On the post with the heavier red seems the only option?
Thanks, yet again!
1948 3/4-Ton 5-Window Flatbed Chevrolet [sandeace.com]
28 Years of Daily Driving. With a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
Re: Alternator Wires
Wally / Montana #1411475 Wed May 26 2021 09:53 PM
The two ring terminals go together on the alternator output stud.
Wally / Montana #1411476 Wed May 26 2021 10:11 PM
Thanks, Hink.
Wally / Montana #1411495 Thu May 27 2021 12:24 AM
The smaller gauge wire is a grounding wire for an idiot light, if you choose to use one. It's also used as an excitation lead to turn the solid state voltage regulator on if you choose to use it that way. Otherwise, it might be necessary to rev the engine up once after starting before the alternator will begin to charge. If you don't choose to use an indicator light and connect the small wire to the ignition system, it's possible there will be enough feedback to the ignition to keep the engine running when the switch is turned off. To prevent that from happening, use a 100 ohm resistor or a diode in the wire to block the feedback current.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Moderated by  Rusty Rod
