The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
E V E N T Highlight
Southern
"STOVEBOLT"
Jamboree 2022
July 8 and 9
Lebanon TN
The Southern Bolters are planning their area get together in
conjunction with the
Southeast Truck Nationals at Cedars of Lebanon State Park (TN)
Check out the details, with new info on the Southern Bolters forum.
Plenty of other events in the Side Lot
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (1 invisible), 77 guests, and 3 robots.
Forums59
Topics128,010
Posts1,036,482
Members45,915
Most Online1,229
Jan 21st, 2020
Page 2 of 4 1 2 3 4
JoeR #1410963 Sun May 23 2021 12:08 AM
I thought the 3/4 ton longer bed had 3 stake pocket supports ILO 2 that the regular 1/2 ton had...??
Larry
All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
JoeR #1410976 Sun May 23 2021 01:45 AM
JoeR #1411037 Sun May 23 2021 03:05 PM
Except for the grill, rear fenders and Rear diff, it looks like my 1939 3/4 ton. The 1/2 ton would have the axle over the springs. The 3/4 will have the axle under the springs. The 3/4 ton would have had an additional short closed drive shaft in front to make up the additional 10" or so of bed length. (kind of like the GMC long bed). Don't want to violate any posting regs, but if you are trying to return this vehicle to original, I know where you can get a 1940 3/4 ton differential free. Send me a private message.
JoeR #1411170 Mon May 24 2021 01:43 PM
JoeR Offline OP
Looks like I've located a pair of '41 rear fenders near me. As I understand it they are the same as the '40. I've also located a 6 lug, 12 bolt rear end with a 3.73 ratio. Anyone know what the WMS to WMS was on the '40? The Oldcarmanualproject manual is missing those pages. The one I've found has 62".
JoeR #1411183 Mon May 24 2021 03:53 PM
Joe,
I think the green truck has been shortened. It also has a '41-'46 hood side panel. I can't find another photo of a pickup with the super short space between cab and rear fender.
Mike
Direct email ml.russell1936@gmail.com
JoeR #1411365 Tue May 25 2021 11:06 PM
JoeR Offline OP
Hey Mike,
Not sure why anyone would shorten a short bed but I guess, as they say, to each his (or her) own. Any thoughts on the 12 bolt, 3.73, 6 lug rear end for this truck? I've also found an online place that has Artillery wheels but I'm thinking they may have to wait until I get the basics done first. I can throw a pair of steel wheels on there for now.
Joe
JoeR #1411372 Wed May 26 2021 01:10 AM
Here are the axle information pages from the above cited book in my previous post.
https://www.flickr.com/photos/advance-design_parts_co/51203415881/in/album-72157631872034068/
JoeR #1411417 Wed May 26 2021 03:14 PM
JoeR Offline OP
Hi Brad,
Thank you for the info. Do you know if what they are referring to as "Tread" is the wheel mounting surface to wheel mounting surface or the center of the tires?
Joe
JoeR #1411454 Wed May 26 2021 06:24 PM
I always understood tread/track to be from center-of-tread to center-of-tread. Maybe someone else knows for sure?
JoeR #1411459 Wed May 26 2021 07:30 PM
JoeR Offline OP
I've always measured complete rear ends from Wheel Mounting Surface to Wheel Mounting Surface. On my '46 stake bed it didn't really matter too much since there were no fenders to deal with. I think I'll probably have to wait until the truck gets here and I can measure the space between the fenders to make sure. Looks like there are several 6 lug units out there so it shouldn't be too much of a problem.
Joe
Page 2 of 4 1 2 3 4
Moderated by  Justhorsenround
