The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Thinking again ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (Gunk, Bill Hanlon, 2ManyTrucks, 55shaker, BC59, 1 invisible), 98 guests, and 3 robots.
Forums60
Topics127,542
Posts1,032,386
Members45,806
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Brake Lines Anyone? 1954 3604 Chevy Truck
#1411252 Tue May 25 2021 02:34 AM
Dusty53 Offline OP
Well, I ordered a complete brake line set from a vendor and low and behold they are not even close. Used their "compatible vehicle " tool and yeah, it showed a match, but no it doesn't. So here's my confusion after doing some research. The Factory Assembly Manual for 1947- 1954 details the brake line part numbers for the 3600 Left Drive in Section 5 , and does not reference different part numbers for the model years. With this in mind, why would the vendors list individual "kits" for the different model years. Does anyone know where the brake line part numbers might be listed other than the Assembly Manual? I didn't find any information on them by using the GM parts Wiki.
Also an interesting find in the shop manual is that 3100 series trucks have 3/16 OD Brake tubes except the cross over from the master cylinder to the junction block on the passenger frame rail which is 1/4 " OD tube. The 3600 and up trucks use only 1/4" OD tube.
Any suggestions ladies and gentlemen?
Ronnie
1954 Chevy 3604 - A work in progress...
" You can't keep dancing with the Devil and wonder why you're still in hell"
Re: Brake Lines Anyone? 1954 3604 Chevy Truck
Dusty53 #1411257 Tue May 25 2021 03:18 AM
I'm planning on building my own brake lines. I ordered a 25' roll of 3/16" brake tubing for most and will buy a short section of 1/4" for the master cylinder to division block piece.
Here's some info for you Brake system illustration. [chevy.oldcarmanualproject.com]
Also this and the following pages. [chevy.oldcarmanualproject.com]
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Dusty53 #1411339 Tue May 25 2021 06:41 PM
I've had really good luck purchasing from O'Reilly's pre made lines. The last one I had to purchase was the one on the passenger side (the first of the 2 piece line heading back to the rear). It was something like $8 and it fit/worked fine. Very easy to shape and work, already double flared with new fittings. They have 1/4 inch line as well. These come in different lengths and diameters.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Dusty53 #1411368 Wed May 26 2021 12:40 AM
ASU Offline
I have found that copper nickel brake line is FAR easier to work with, if you are buying bulk and bending your own. easy to bend form, no corrosion to speak of. You just have to have the skill to flare the ends.
Jon
ASU #1411395 Wed May 26 2021 12:12 PM
AD Addict
Jon
I couldn’t agree with you more! I used CU-NI for all of the lines I have replaced so far and it bends beautifully but if you don’t have one of the pro flaring kits, that cost hundreds of dollars, you have to practice your flares. The biggest thing is to keep the flaring tool centered on the anvil. Check it just after contact and before you tighten it down. If its not centered, the flare will be lopsided and will not seal properly. Once I realized my mistake, my flares came out nearly perfect.
Here is the flaring tool I use. It’s an Imperial.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Phak1 #1411482 Wed May 26 2021 10:52 PM
I hope you are making double flares and not just single flares (low pressure for plumbing)...you didn't show the adaptor dies.
These double flare tools are cheap and work fine for the hobbyist...just take your time and practice once or twice and you'll be a pro!
https://www.amazon.com/Wostore-Doub...Y2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
Mike B smile
Dusty53 #1411484 Wed May 26 2021 11:19 PM
AD Addict
Definitely double flares. I only showed the style I have (from the internet) not the complete set. My flaring kit is is from the 70’s and I do have the anvils to complete the double flare.
Here is a picture of what my kit looks like.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
12v w/ Alternator
Dusty53 #1411504 Thu May 27 2021 01:13 AM
Dusty53 Offline OP
Thanks everyone. Ron (me) is going to be learning a new skill.
Ronnie
Dusty53 #1411590 Thu May 27 2021 04:07 PM
These days, I try to stick to 37 degree.
If you do enough brake lines, the hydraulic, or even the long handled machine, is well worth it. Eastwood sells a decently priced version.
Moderated by  SWEET
