The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Thinking again ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (DougH6100, 78buckshot, Paul_WNC, D B Cooper, Steve L., 1 invisible), 63 guests, and 3 robots.
Forums60
Topics127,583
Posts1,032,706
Members45,812
Most Online1,229
Jan 21st, 2020
Image Posting Policy
350 pre-lube trouble
#1411104 Mon May 24 2021 12:22 AM
ASU Offline OP
Working on the 350 engine out of my 71 K1500. The history is I wiped a lobe off the cam a few months ago. It was #7 exhaust. Anyway, I finally got around to pulling the motor to replace the cam. New cam, timing chain, lifters, push rods and gaskets.
I got to the point that I wanted to run the oil pump with a drill to pre-lube everything. The motor is still on the stand, with the intake manifold off yet. The "odd" side pushrods bubbled and got oil, but I cant get oil to come out the push rods on the "even" side. I ran the oil pump for probably 15 minutes. Am I missing something? My next thought was to pull the pushrods and lifters out of that side to make sure they were getting oil from the block, but I haven't got that far yet.
Any other wisdom?
Jon
Re: 350 pre-lube trouble
ASU #1411106 Mon May 24 2021 12:26 AM
If a distributor housing isn't installed, the lifter oil gallery down one side won't receive any pressure. No oil to the rocker arms on that cylinder bank is the result. I use a junk distributor with the teeth ground off the gear as a priming tool to prevent that problem.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
ASU #1411137 Mon May 24 2021 03:31 AM
You're chasing normal operation. Good on you for noticing the side to side difference, but you've primed it as far as you can by just turning the pump. Go ahead and install the intake and distributor and cycle the engine with the starter to confirm oil on both sides, then prime the carb and fire it off.
ASU #1411147 Mon May 24 2021 08:52 AM
ASU Offline OP
Thanks HRL and Hink. Appreciate your wisdom!
Jon
ASU #1411342 Tue May 25 2021 07:12 PM
Another thing that I do before firing the engine is dribble some oil in on the heads around where the pushrods are, that way you're being proactive and going DOWN with oil, instead of waiting for fresh oil to come UP.
Fire that baby up! It can take it! I just did the same last August grin
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
Hotrod Lincoln #1411359 Tue May 25 2021 10:10 PM
I'v got an old distributor (87 - '95 TBI) w/ the gear removed, stick it in the hole & spin it with a drill. Doesn't hurt to rotate the engine some to get oil to all the rod bearings.
BC
1960 Chevy C10 driver 261 T5 3.73 dana 44
1960 C60 pasture art
ASU #1411367 Wed May 26 2021 12:36 AM
ASU Offline OP
Thanks guys. Sounds like my easiest option is to leave spark plugs out and carb off and crank it with the starter once its in the truck. Most likely a weekend project!
Jon
ASU #1411369 Wed May 26 2021 12:59 AM
If you're running a new cam and lifters, don't overdo it on the cranking. You'll wipe all the assembly lube off the cam, and end up with a few damaged lobes. Just start the thing, and as soon as you see oil pressure, rev it up to 2K RPM or so and keep it there for 20 minutes or so. It helps if you have the ignition timing set right and the valves pre-adjusted so you don't have to tinker with it instead of just running the engine. Use a big box fan or a squirrel cage blower in front of the radiator to prevent overheating during the break in run.
Kris Kristofferson
ASU #1411380 Wed May 26 2021 02:31 AM
I'm with HRL, easiest & best are not the same.
BC
Moderated by  Woogeroo
