The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (3hansens, 55shaker, 68ironhead, ApacheFiend, 3 invisible), 103 guests, and 5 robots.
Forums60
Topics126,065
Posts1,018,869
Members45,419
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Oil gallery question?????
Hotrod Lincoln #1411062 Sun May 23 2021 07:19 PM
I'm thinking that hydraulic roller lifters on a solid lift cam will slightly increase the duration and lift, since the valve will actually begin the lift cycle on what's supposed to be the clearance ramp, and stay open a few degrees longer. I might have to do some tinkering with the opening point by using offset Woodruff keys on the cam and/or the crankshaft.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
Hotrod Lincoln #1411069 Sun May 23 2021 08:22 PM
Is there a roller cam grind which could be used instead of the solid lift cam, Jerry? Maybe with a shorter or reduced clearance ramp and a more pronounced dropoff? Or could the solid lifter cam be modified?
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Hotrod Lincoln #1411071 Sun May 23 2021 08:33 PM
The lifter holes in my 261 are w/o lifters and exposed so I put in a strip of paper and pressed it with my finger. The indentation has a diameter of 1/2".
1948 3/4-Ton 5-Window Flatbed Chevrolet [sandeace.com]
28 Years of Daily Driving. With a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
Hotrod Lincoln #1411072 Sun May 23 2021 08:34 PM
If there is (and I doubt if it even exists), it would be horrendously expensive. I recall seeing a roller cam blank for Chevy NASCAR engines on the shelf during a guided tour of Comp Cams' facility in Memphis. The blank, just a solid round billet of steel with a distributor gear machined on the end, was priced at $800.00. Grinding the customer's profile on it was extra- - - -a LOT extra! At that time, in the mid-1990's, a billet crankshaft from King's was priced at $5500.00, and a set of Carrillo connecting rods was about $1200.00. "It's expensive to go fast- - - - -how fast can you afford to go?"
I'm probably getting close to the maximum lobe lift anyway, since I've machined and ground the large cam bearing journals of the "Corvette/261" cam down to fit the 216 cam bearings. It fits, but just barely!
Kris Kristofferson
Hotrod Lincoln #1411073 Sun May 23 2021 08:35 PM
Thanks, Wally! That's what I thought, but it's good to have some confirmation!
Kris Kristofferson
Hotrod Lincoln #1411075 Sun May 23 2021 08:52 PM
I went out today after I got home and my 59 235 has 9/16 oil galley. the soft plugs are the same size and look to be swaged in after installation, not punched but the entire diameter of the hole has a ring type swage all the way around. The galley is fed from both ends of the main bearings.
Hotrod Lincoln #1411085 Sun May 23 2021 09:51 PM
Here's a picture of the gallery getting fed from each end like lumbersawyer said. It came from my copy of Motors Truck Repair Manual (1969 edition). I find this book very, very useful especially since my 1961 261 isn't in my 1948-51 shop manual.
The arrows showing oil flow are a bit small.
Hotrod Lincoln #1411107 Mon May 24 2021 12:34 AM
Gotta head to central Mississippi early tomorrow morning to look at a car that caught fire after Walmart put a new battery in backwards! I have feeling Wally World is in for an E$$$$$pensive problem with this one! I'll press on with making my block-drilling fixture whenever the boss cuts back on my road trip schedule a little.
I've got a couple of Motor manuals with the same diagram. Since there was never a hydraulic lifter version of the 216, the closest thing I can think of to compare with would be a 235 spray-oiler from an early Chevy Powerglide car.
Kris Kristofferson
Page 2 of 2 1 2
Moderated by  Woogeroo
