The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (homer52, lumbersawyer, Harold41, dands, D B Cooper, 2 invisible), 136 guests, and 6 robots.
Forums60
Topics124,729
Posts1,006,726
Members45,019
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Connecting wires on fuel gauge
#1410950 Sat May 22 2021 10:06 PM
I am hooking up the fuel gauge on my 1948 half ton. 2 terminals on the fuel gauge. I put the sending unit wire on the thicker shorter terminal. I put the wire from the ignition switch on the longer thinner terminal, this terminal is near the driver's door. Do I have the wires landed correctly?
The shop manual is vague on landing the wires. It says put the sending unit wire on the larger terminal. I don't know if thicker or longer is larger. It also says ignition switch wire on the left terminal on the back of the dash. It is not clear if this is the left when you are in the drivers seat or the left when you are looking at the terminals from under the dash.
Re: Connecting wires on fuel gauge
gallatin #1410955 Sat May 22 2021 10:34 PM
Scott Voss colorized this diagram of the back of the gauges. I believe it's for a 1949 3600. I found it helpful when I was rewiring my '47.
Andy
His: 1947 Chevrolet 3104 [flic.kr]
Hers: 2008 American Saddlebred [flic.kr]
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
gallatin #1410975 Sun May 23 2021 01:39 AM
Sir Searchalot
A shape/feature that is round, like a threaded terminal stud, is referred to in the electro-mechanical/automotive world as a diameter. Likely they meant, in engineering terms, "larger diameter". Thicker is used for thickness. The manuals are written by technical engineering people of the day. If they meant longer, they would have said longer.
It seems you have it wired correctly according to what you say the manual says.
I see you are an Engineer. Me too.
Watch out for careful drivers!!!
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
I used to think beer was bad for me, so I gave up thinking.
Sometimes no nonsense makes sense, in a sense.
You can't teach a new dog old tricks.
Honk if you're Amish
HandyAndy #1410986 Sun May 23 2021 03:15 AM
Andy, thanks much! This is useful info!! Sending unit wire to the thicker shorter terminal.
Moderated by  Rusty Rod
