What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Forums59
Topics128,581
Posts1,041,657
Members46,052
Most Online1,229 Jan 21st, 2020
OP
Anybody ever had one of these in their vehicles? Inline 4, base engine for the smaller 60s cars as well as the 1964 Chevy van.
I will have to research that one. I seem to remember one or two here in Kissimmee. Was it made by Opel by any chance? Doc.
I believe Coilover has one in an early Chevy truck- - - -like late 1920's or early 30's vintage. After Chevy quit putting them in cars, Mercruiser built untold thousands of inboard/outboard stern drives on that platform. I've got plans for a doodlebug tractor based on one of several Mercruiser engines I have. They were also used in the right hand drive post office Jeeps a long time ago. It's got the same bellhousing bolt pattern as a small block V8 which makes adapting to lots of transmissions easy. Jerry
"Freedom's just another word for nothing left to lose" Kris Kristofferson Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self. Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
OP
Not sure if it was built by Opel. Thought it was a Chevy.engine because of so many interchange possibilities. It had the same bore and stroke as the 230 and 307. Seems a bit puny to power a half ton van, maybe that's why they dropped it after only one year.
Most of those Chevy vans, especially the ones decorated with "flower power" symbols, spent more time parked than they did on the road, so engine size wasn't much of an issue. The springs and shocks wore out pretty quickly, though! https://www.youtube.com/watch?v=IBNRfZlGatwLOL! Jerry
The 153 engine was used in the first version of the Chevy II in the early 1960's.
Mixed Up
Jerry I lived that song many many times in the 70's!! That 65 Chevy van came with a 230 six.
Don
The engine Opel was running at that time was an oddball 1.9 Liter 4 cylinder overhead valve with the camshaft located near the top of the engine block, just under the cylinder head. The pushrods were only about 3" long. The Chevy 4 cylinder engine was basically a 230 with a couple of cylinders lopped off. That's sort of like some of the Chevy V6's that were more of less shortened V8's. Jerry
