The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (Gazz, 55shaker, 1955first6500, GMJim, Hotrod Lincoln, 2 invisible), 281 guests, and 3 robots.
Forums60
Topics123,450
Posts996,251
Members44,670
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Threaded holes
#1410279 Tue May 18 2021 12:57 AM
Gents,
For the life of me, I can't figure out what goes in each hole!
2 numbered pictures, 7 total threaded holes with colored arrows
One should be for an oil pressure gauge? In my before pictures there is nothing there.
Any help would be appreciated!
Chris
FYI engine is a 1961 261
Re: Threaded holes
ndkid275 #1410288 Tue May 18 2021 02:58 AM
AD Addict
The holes in a triangular pattern on each side may be for side mounted motor mounts.
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Re: Threaded holes
Phak1 #1410298 Tue May 18 2021 05:05 AM
That's correct.
Don't think the hole above the oil line with the green arrow is threaded, should be the oil flow pin. When driven in it's for the full flow oil filter. If pin is flush it's setup for bypass oil filter only If pin is driven in it must have external oil lines!
BC
1960 Chevy C10 driver 235 T5 3.73 dana 44
1960 C60 pasture art
G.M dealer tech since 1980 & counting
Re: Threaded holes
ndkid275 #1410301 Tue May 18 2021 11:09 AM
Ok, do if that is the case, where do I connect an oil pressure gauge?
Re: Threaded holes
ndkid275 #1410307 Tue May 18 2021 12:09 PM
AD Addict
Place a tee in the oil supply. One side goes to the filter and the other side goes to the oil pressure gauge.
I added a second tee so I could add a second oil pressure gauge at the engine.
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Re: Threaded holes
ndkid275 #1410311 Tue May 18 2021 12:48 PM
It looks like you have your filter lines bushed down to 3/8”. I don’t think that is going to supply enough oil for a full flow filter system. I believe that originally they used 1/2” tube.
My Blog
Re: Threaded holes
ndkid275 #1410415 Wed May 19 2021 02:07 AM
I'm am using original everything. I changed the one fitting back at the “in” to the filter.
Chris
Moderated by  Woogeroo
