The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (Hotrod Lincoln, jo's54hydramatic, JW51, DennisM, 55_2nd_Series, 66rollback), 88 guests, and 3 robots.
Forums59
Topics128,614
Posts1,041,935
Members46,061
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1409939 Fri May 14 2021 11:24 PM
Csims Offline OP
Wound this for sale and was wondering how this would be for a engine swap. Would be a up grade for hp and still somewhat original.
Csims #1409940 Fri May 14 2021 11:26 PM
Csims Offline OP
Sorry working on a picture
Csims #1409979 Sat May 15 2021 03:59 PM
Csims Looks like a good find,those ran fine assume it is 348 nice rod engine,kinda sick of 350,s . Good to zoom up to the gas station in !!
Csims #1409998 Sat May 15 2021 06:22 PM
That one (being from 1958) might have the rope rear main seal and if it does, you can not use the rubber seal in it. GM changed the design to a 2 piece rubber seal later in 1958. A friend had one of the early ones. He liked the engine, but it leaked seriously and as I recall you had to pull the engine to replace that rope seal. Might be worth getting the engine number and seeing if you could figure out more about it. Good luck.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Csims #1410006 Sat May 15 2021 07:03 PM
I had that engine in my 1958 Impala convertible. It's the largest stock 1958 Chevrolet engine, called the "W", it's the ancestor of the 409 and 396/427/454 etc.
A more modern engine will be easier to rebuild and service, but those valve covers!!!
No small blocks allowed.
Csims #1410011 Sat May 15 2021 08:14 PM
The 348 was intended to be a low RPM, high torque medium duty truck engine- - - -never intended to be installed in passenger cars. Above 5500 RPM, the valves start to float. Then in 1957, the supercharged Ford 312 engines started eating the 283 Chevy's lunch at the drag strips. GM cast a 3-2 BBL intake, stuffed a hot cam into the 348, and shoved it into the 58's to buy a little time while they got the 327 into production. They made good anchors for big boats back then- - - -60-something years hasn't changed that much, if any. The 348's 409's and early 427's with the W valve covers all had an oddball angle between the pistons and the heads- - - - - the "combustion chamber" is actually a part of the cylinder. The only recess in the head is a tiny depression where the valves fit. The heads are notorious for getting heat cracks due to uneven cooling.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
Csims #1410647 Thu May 20 2021 04:52 PM
Crusty Old Sarge
I know the 348 and 409 were a short run for Chevy. They were not really known for making power, and had a host of issues from the start. Even the great Smokey Yunick said you couldn't make power with those engines. You do have to agree that it's still one of Chevy's best looking engines.
Craig
Come, Bleed or Blister something has got to give!!!
Csims #1410730 Fri May 21 2021 06:29 AM
I would love to have that motor for my Apache, if and/or when the 235 is not longer rebuildable.
58' 3200 235 3-speed/OD
Csims #1410775 Fri May 21 2021 04:32 PM
I've got the 348's big cousin in my 61 American LaFrance fire truck- - - - -a 401 GMC V6. It's got the W-shaped valve covers also!
Kris Kristofferson
Ernest Hemingway
Hotrod Lincoln #1410793 Fri May 21 2021 06:11 PM
Carburetion specialist
In addition to the tripower, Chevrolet offered a Carter AFB single four barrel on an engine they called "Super Turbo-Thrust".
The posers bought the tripower.
The racers bought the four-barrel.
The engines produced more power (regardless of the marketing dept.) and had less heat cracks due to better A/F distribution with the four-barrel than with the tripower.
Jon.
The most expensive carburetor is the wrong one you attempt to modify
If you truly believe "one size fits all" try walking a mile in your spouse's shoes!
[image]http://www.thecarburetorshop.com/Avatar.jpg[/image]
Page 1 of 2 1 2
Moderated by  Justhorsenround, KCMongo
