The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Hello there ...
We have a request from "Harold46".
Curious?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (Rich'sToys, mikebrou, tesa, Mather, Harold46, 1 invisible), 195 guests, and 3 robots.
Forums60
Topics124,036
Posts1,001,032
Members44,820
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Headliner removal later '49
#1409188 Sun May 09 2021 04:24 PM
Unrepentant VW Lover
Charlie's headliner (at least the front half) has not been touched since it was installed on the assembly line. I had to remove the back part to install the seatbelt kit ... and it went very well -- I was able to remove it and reinstall it without damaging it.
Back to the front ... Because this is the later '49 and does not have the removable center retainer, will I be able to just gently push it out and remove it after I remove the inner windshield frames?
Something is going on behind it that is causing a rust spot on the windshield frame and I suspect a mouse nest. I want to save the headliner if I can because it's original and its in good shape, other than this rust issue /soft spot.
"Of all tyrannies a tyranny sincerely exercised for the good of its victims may be the most oppressive."
— C. S. Lewis
'49 Chevrolet 3804
Re: Headliner removal later '49
John Milliman #1409391 Mon May 10 2021 09:10 PM
My 51 has a 2 part. Once I remove the window frames (includes visors) and screws in the back, mine come right off. I assumed that your old marine corps eyes missed a screw.
John Milliman #1409409 Tue May 11 2021 12:03 AM
Thanks Chris -- I haven't tried yet. What screws in the back? Back of what? Can I just remove the front half, or do I need to remove both front and back?
I am not looking forward to what I am going to find ...
Charlie needs as new home ... frown
— C. S. Lewis
'49 Chevrolet 3804
John Milliman #1409422 Tue May 11 2021 01:52 AM
If it’s a 2 part headliner, I would take out both in one piece. You might wreck the cardboard. Mine has screws holding the cardboard to the metal just above the window. If you need pictures, just ask.
Chris
John Milliman #1409453 Tue May 11 2021 11:57 AM
Chris -- I've removed and replaced the rear piece before but I have not messed with the front half. I guess I will just go at it carefully and hopefully I can intuit my way through it.
— C. S. Lewis
'49 Chevrolet 3804
John Milliman #1409601 Wed May 12 2021 12:55 AM
Was able to stop by the garage this afternoon on my way home from the dentist ... Met up with Hambone. Anyway ...
There was no way to save the front half of the headliner. Turns out that it *was* a mouse nest. A big one. Recent, too. But enough that it caused the stain in the headliner and fresh rust on the inside windshield frame. Anyway, with Hambone's assistance, it headliner came out in pieces and I was about to hit the rust with a wire brush and spray the whole thing with rust converter. I think we caught it before things got too far. The headliner was original and and this was the first time the inside of the cab roof has seen daylight since August, 1949.
I saved the visor, though.
— C. S. Lewis
'49 Chevrolet 3804
John Milliman #1409620 Wed May 12 2021 03:28 AM
I hate rudeness in vermin. Won't tolerate it.
John Milliman #1409727 Thu May 13 2021 12:52 AM
Since you pulled it out, you should consider Formica as a replacement.
Chris
John Milliman #1409958 Sat May 15 2021 10:49 AM
Formica?
— C. S. Lewis
'49 Chevrolet 3804
John Milliman #1409965 Sat May 15 2021 01:03 PM
Shag. Think of it. Outside the box.
HB
1966 Chevrolet K-10
Flappy Fenders
In the Stovebolt Gallery [stovebolt.com]
More pictures on Photobucket [s160.photobucket.com]
1962 Chevrolet C10
1962 Suburban
Page 1 of 2 1 2
Moderated by  ndkid275
