The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (Beast57, Kerwin, Gooberdog, coach-frank, 2 invisible), 222 guests, and 3 robots.
Forums60
Topics122,979
Posts992,321
Members44,573
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Wheel progress on 50 6400
#1407322 Sat Apr 24 2021 06:52 PM
MT1950 Offline OP
Found something that works for me -Locking Ring wheels off of a 47 to replace my RH-5s. These are a little narrower, so some won’t like the look, but they accepted the 8.25 20s. Rears are still RH-5s, but thinking of doing the same back there. First place I went to couldn’t figure out how to mount these - next place had an old farm kid that said no problem and cranked em out on an hour. I had demounted the old one and cleaned up the rims and rings - glad to be mobile again.
Re: Wheel progress on 50 6400
MT1950 #1407333 Sat Apr 24 2021 10:41 PM
Where did you find the wheels? I have 19.5" on my 52 6400 and they look small, but so far I can't find anything else.
1954 Chevy custom 261CID, T-5 5 Speed.
1952 Chevy 6400 2 ton hydraulic flat bed.
MT1950 #1407334 Sat Apr 24 2021 10:58 PM
Keep digging for 22.5’s, might be on odd trucks, not always 20’s on same truck. Old farm trucks are the most common. Don’t ask, price might go up or they don’t know what you are talking about. Have to look yourself.
Ed
MT1950 #1407343 Sun Apr 25 2021 12:36 AM
MT1950 Offline OP
These were spares from a 47 we had around the place until a few years ago - had I been thinking I would have swapped out the rest of the RH-5s before it was hauled off.
MT1950 #1407628 Tue Apr 27 2021 04:16 AM
9
MT1950 I have wheels if interest pm
Karl j Townsend
MT1950 #1408617 Tue May 04 2021 04:57 PM
MT1950 Learned from pipe fitters to use a needle scaler,like they clean-up welds with to knock off sale on wheels. Then use por 15 rust absorbing paint this leaves a lot more integrity in your wheel than sandblasting.Especially on wheels that wont be exposed to such demanding weather conditions. Done some 20 yrs. ago still look fine !!
9% grade #1408620 Tue May 04 2021 05:07 PM
9% grade On the later wheels (with a bigger center hole) can you use those on earlier trucks ?? Have some clean oilfield wheels with 7;50 rubber,can turn out a spacer.
oldieoldie #1409328 Mon May 10 2021 02:49 PM
oldieoldie where didd your 19.5's come from ?? Never saw any 19.5's in the picture the UPS wheels don't really look right either,but if its all you can find gotta go with em !!!
fixite7 #1409340 Mon May 10 2021 04:05 PM
9
Yes with spacer,the later 5 1/8" center hole can be used on earlier hubs
Karl j Townsend
MT1950 #1409780 Thu May 13 2021 04:02 PM
Tubeless 19.5" wheels are direct replacements for an 18" tube type tire and wheel setup. Around Nashville, the older bread trucks built on a 1 ton chassis used to run them, for some reason. Probably because roadside tire changes were quicker- - - - -leave the wheel mounted on the truck, pry the flat tire off and install the new one, and use starting fluid to pop it and create a bead seal so it could be aired up the rest of the way. Much faster than removing the wheel and fighting with a sectional wheel!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Moderated by  69Cuda, Grigg
