The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (EdPruss, campbell45, DennisM, 3100Cummins, Donf, 3B, 1 invisible), 248 guests, and 3 robots.
Forums60
Topics122,980
Posts992,323
Members44,573
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1955 Front Suspension
#1408465 Mon May 03 2021 07:25 PM
Pete O Offline OP
I have a 1955 second series with a 1978 Camaro front suspension. I recently cut the front coil springs to lower the front end. The truck squeaks like crazy now. Can someone tell me if the upper spring or lower spring that is most likely causing the squeak? Can I fix the squeak without taking out the spring? I know that it's a tuff call, but, what is the most likely issue?
Re: 1955 Front Suspension
Pete O #1408533 Tue May 04 2021 02:19 AM
How did you cut the spring...with a saw or torch?
Did you deburr the cut end?
Did you cut it so the new cut end is riding in the same spot as before you made the cut?
Maybe the HiPo Shop guys can help...
Mike B smile
Pete O #1408588 Tue May 04 2021 02:23 PM
Mike got it, but in my experience even professionally cut coil springs that ride metal to metal will squeak. I think you need to replace your coil spring insulators (these are made for nearly all vehicles up through the 80s). You compress the spring, slip the pad underneath the coil, turn the spring back to its original location if it is top-oriented and then un-compress it. They don't change the height, but they do make things quieter. If you cut the coil with a torch and didn't chamfer the cut edge after you cut it, I'm afraid you're going to have to remove it. If the edge is cut crudely enough it will cut through any insulator and you'll have the same problem. Good luck.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Pete O #1408589 Tue May 04 2021 02:25 PM
Oh, forgot...you have to remove the shock absorber, also. Physically impossible to slide the pad in unless you do this.
Jon
Moderated by  KCMongo
