Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
16 members (Cletus1950, Achipmunk, BC59, baldeagle, COCOE, Awneill1975, 1 invisible), 179 guests, and 3 robots.
The Zone
Forums65
Topics123,452
Posts999,595
Members47,279
Most Online1,229
Jan 21st, 2020
#1408231 Sat May 01 2021 11:47 PM
JustinB Offline OP
Moderated
I have a pretty good leak in the old RTV in the rear diff cover. I am thinking about painting the rear end while I have the cover off, and possibly getting a new diff cover. Can anyone help me identify the rear end. I think it is stock, but I am not sure if they had a drain plug in the bottom like this one or maybe it was added by someone along the line. Kind of hard to see the drain plug I am talking about in the pics. Just not sure what to search to find a cover that will fit. Thank you.
Forgot to mention that it's in a 1958 Chevy 3200.
JustinB #1408237 Sun May 02 2021 12:31 AM
Why are you getting another cover? You mean a new gasket for the cover? Is the plug at the bottom and requires a hex wrench? I put a hex drain plug at the bottom of mine and love it.
Craig
My '50 Chevy 3100 5 window, 235cu
My truck [cmaynard.com]
If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
JustinB #1408247 Sun May 02 2021 01:36 AM
“Grease Monkey” “Former herder of cats”
It would help if you told us what your working on.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
cmayna #1408248 Sun May 02 2021 01:40 AM
JustinB Offline OP
Moderated
Was just thinking about it. Not sold on getting a cover for sure though. Yea it’s a hex drain on the underside. I have the shop manual and it looks stock but I don’t see that drain plug in any of the pics from the manual so I wasn’t sure. Is there a specific name for this diff to find out more info. Probably a stupid question, but I have only really worked newer vehicles before this truck.
JustinB #1408255 Sun May 02 2021 02:29 AM
I think you will find that cover fits 1940-62, as will the gasket.
My Blog [chev235guy.blogspot.com]
JustinB #1408257 Sun May 02 2021 02:32 AM
I don’t see a drain plug,is it under were the bump is on the cover
kevinski
1954 GMC 9300
JustinB #1408260 Sun May 02 2021 02:37 AM
I believe that if you remove the bottom bolt of the cover the gear lube will drain out. Just remember to put some sealant on the threads of that bolt when you reinstall the cover.
Rusty
JustinB #1408271 Sun May 02 2021 04:02 AM
JustinB Offline OP
Moderated
Hey guys, thank you for the responses. I think what I am trying to ask is if this is the stock '58 rear end? Also, is there a way to identify it when I am searching online for parts? For example if I am searching for a cover for a 8.2 GM 10 bolt I will get exactly that, or a Ford 9. But I am not sure what to type in when looking for this rear end.
JustinB #1408280 Sun May 02 2021 11:58 AM
AD Addict
I just did my ‘52 3100 with the stock torque tube,. It looks just like yours, and I just loosened the bolts and pried the cover back on the bottom to let it drain. I reinstalled with a new gasket and used anti-seeze on the cover bolts. No leaks.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery Forum
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
Updated to: 12v w/alternator, HEI & PCV
JustinB #1408294 Sun May 02 2021 02:38 PM
If you do infact have a drain plug at the bottom of the diff, be sure to think about the plug when you use a floorjack on the diff. Later today I will show a pic of what I use along with the floor jack when it comes jacking up the backside.
Craig
