The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (3hansens, 55shaker, 68ironhead, ApacheFiend, 3 invisible), 103 guests, and 5 robots.
Forums60
Topics126,065
Posts1,018,869
Members45,419
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Rochester carb ??
#1408105 Fri Apr 30 2021 10:09 PM
I looked at the Rochester carb that was on my 235 today. It was very clean inside and all I need are a few gaskets and accelerator pump. How do I identify the carb? It looks like the other post that buoymaker posted a picture of.
Is it the 7003536 -C-14 number that is on the bottom of the bowl? When looking at carb kits they are not very accurate in the pictures of the parts. The accelerator pump on my carb has a round shaft not flat like they sometimes show in the pictures. It has a automatic choke that was not complete, the bimetal spring was missing. The exhaust manifold has a shield that would of had a heat tube originally. But that is not there. It has a manual choke now. This engine is a 59 truck 235 by serial number.
Re: Rochester carb ??
lumbersawyer #1408109 Fri Apr 30 2021 10:41 PM
AD Addict
The carbs originally came with a tag attached to one of the screws that fasten the top cover on. Many of these tags were lost during a rebuild. On some (not all) of the carbs, they stamped the last 4 or 5 digit number on the base where it attaches to the manifold. Add 700 to the beginning of a 4 digit number or 70 for a five digit number. In my case it would be 7005921. Hope this helps!
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
lumbersawyer #1408112 Fri Apr 30 2021 10:56 PM
Insomniac
That number is the bowl casting number - pretty well useless.
Carb # should be something like 7013029 or 7013953.
Gord
1954 1/2 ton 235 4 speed
lumbersawyer #1408134 Sat May 01 2021 01:29 AM
Ok, the cast base does have some numbers stamped on it. Looks to be 12127.
lumbersawyer #1408142 Sat May 01 2021 02:54 AM
Insomniac
https://www.thecarburetorshop.com/Kchevrolet1.htm
1958 6 235 S/T Rochester BC 7012127 2639
Gord
lumbersawyer #1408145 Sat May 01 2021 03:12 AM
Thanks, I tried finding carb kits for a one barrel and got a varied search result. So a Rochester BC with standard trans. My engine serial is a truck engine and I was told the carb with a automatic choke was for a car not a truck,Thanks much.
lumbersawyer #1408150 Sat May 01 2021 03:37 AM
Insomniac
Yes, it's listed here as a carb for a car. The number is the important thing just so you get the correct kit.
Gord
Gord&Fran #1408174 Sat May 01 2021 12:36 PM
Carburetion specialist
The "2639" in the post above is the number of the rebuilding kit.
Jon.
The most expensive carburetor is the wrong one you attempt to modify
If you truly believe "one size fits all" try walking a mile in your spouse's shoes!
[image]http://www.thecarburetorshop.com/Avatar.jpg[/image]
Moderated by  Woogeroo
