The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Time to gathering together!
Fall Happenings
Since we put up promos last two weeks, we have had a bunch of activity in
The Side Lot.
See what's happening with a Stovebolt Collective near you
THE SIDE LOT
From Coast to Coast and some International gatherings listed, too.
Next up: too many to list!
THE SIDE LOT.
Go see!
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (NJC, Greg C, Gdads51, D B Cooper, fixite7, EdPruss), 76 guests, and 4 robots.
Forums60
Topics129,208
Posts1,047,840
Members46,222
Most Online1,229
Jan 21st, 2020
Page 2 of 2 1 2
Originally Posted by TBUChevy
I have also seen people ruin a good sealing surface when the drill bit jumped.
That is a good point, but wouldn't be an issue with a timing cover seal as the sealing surface is laying on the workbench (on the balancer). A light tap with a center punch helps keep the drill in position.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
pjdee #1408085 Fri Apr 30 2021 07:30 PM
AD Addict
With such a small bit, I would be concerned about the bit going in too far, having it catch on something inside and snapping off because you know that once you break thru, that drill is going to want to go in full depth. I would use a drill stop or a piece of tape limiting the depth, to help prevent such a disaster from happening.
Phil
Moderator, The Engine Shop & Interiors
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery Forum
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
pjdee #1408117 Fri Apr 30 2021 11:13 PM
Good point Kevin. I work on too many different cars. I forgot that the sealing surface was the OD of the hub on the backside of the balancer.
Thanks for catching my mistake.
Rusty
pjdee Offline OP
Ok, I had a chance to remove the radiator and the grill.
I’ve got a puller and will try to remove the harmonic balancer soon.
Ideally I’d like to try to leave the timing cover on.I ordered a speedy sleeve and front seal from Rock Auto.
Thanks again for all the hints and tricks!
pjdee #1409091 Sat May 08 2021 03:38 PM
pjdee Offline OP
Hey guys, getting ready to reinstall should I put ib weld in the grooves on the damper shaft? Thanks, I am using a Speedy Sleeve,
pjdee #1409213 Sun May 09 2021 07:50 PM
If I remember correctly, the speedy sleeve should have come with a compound you use to attach the sleeve and that is all you should need to use.
58' 3200 235 3-speed/OD
pjdee #1409296 Mon May 10 2021 12:03 PM
AD Addict
With the depth of those grooves, I would fill them with JB Weld first, then use a non-hardening sealer as specified in the instructions. I used some type of Loctite, but can’t remember which one.
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Page 2 of 2 1 2
