The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (FAST55, RdsLessTaken, Hotrod Lincoln, 29tons, Flatblu4748), 273 guests, and 3 robots.
Forums60
Topics123,448
Posts996,246
Members44,670
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Top Cowl Vent Repair
NorthCoast3800 #1406920 Wed Apr 21 2021 12:53 AM
100% agree on the compressibility. I just got it to sit slightly proud by cutting the outer perimeter, but getting it to sit tight enough to seal remains a challenge (it just does not want to well, compress!). If it was slightly softer, the final close would seal it - but that force required on the lever is significant (and my vertical adjustment ends up slipping when I apply that much force).
Will order one of those Steele gaskets right away.
Edit: Shipping to Canuckistan from the one supplier will be a minimum of $55 USD (about $80-90 Canuck) so I'll keep searching for that...I will if I have to but I'm sure I can dig one up for a little less.
Thanks very much!
1949 Chevrolet 3/4 Ton - Still Solid.
NorthCoast3800 #1406938 Wed Apr 21 2021 02:36 AM
AD Addict
Originally Posted by NorthCoast3800
Shipping to Canuckistan from the Filling Station will be a minimum of $55 USD (about $80-90 Canuck)
Ouch! Shipping these days is a killer. I don’t blame you for looking elsewhere.
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
NorthCoast3800 #1406945 Wed Apr 21 2021 03:14 AM
I tried some new bolts in the vertical adjustment and made sure the tabs were fully bent out (per the "Servicing Truck Cabs" instructions) and it is thankfully doing a better job of sealing now. But I don't think the gasket modification is a great one, considering it allows water to sit in the space.
Edit: Located one direct from Steele, shipping was "tolerable". The joys of international shipping, especially these days... but It's on the way! smile
NorthCoast3800 #1406955 Wed Apr 21 2021 09:56 AM
Unrepentant VW Lover
Good feedback. FWIW, I got one of the hard, flat ones about 10 years ago for my truck. After 10 years, it still leaks. frown I, too, will look into the expensive one from Steele.
"Of all tyrannies a tyranny sincerely exercised for the good of its victims may be the most oppressive."
— C. S. Lewis
'49 Chevrolet 3804
NorthCoast3800 #1406956 Wed Apr 21 2021 11:32 AM
AD Addict
I agree with John, good feedback. I have to get one for my ‘52 and I will definitely buy one from Steele.
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
NorthCoast3800 #1407245 Sat Apr 24 2021 03:28 AM
I have gotten so mad at the lack of quality of the rubber cowl seals, that I bought 2 the soft foam seals.
I put one in the cowl, but it would not seal, so I added the other one to the underside of the vent. I had to shorten it so that it would fit by cutting out about 3/8".
No more leaks!
NorthCoast3800 #1409810 Thu May 13 2021 09:17 PM
My Steele Rubber gasket showed up this week which is incredibly fast these days compared to other stuff I've had shipped lately. It is a MUCH different seal than the one I installed above. This one has a lip and is noticeably more malleable (as others stated).
Unfortunately this weekend is tied up so I won't likely get to this for another week yet, but I'll update when I do!
Page 2 of 2 1 2
Moderated by  HandyAndy, klhansen
