The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (Hotrod Lincoln, DavidBraley, 55shaker, FAST55, Gone, Jon G, 1 invisible), 277 guests, and 3 robots.
Forums60
Topics123,448
Posts996,244
Members44,670
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Restoring Door Hinges - 1952 3100
#1406822 Tue Apr 20 2021 01:58 PM
Gib70 Offline OP
I am seeking guidance on restoring the door hinges on my 1952 3100. Please see enclosed pictures. The new hinge pins came with brass bushings. The second picture depicts where I think the bushings would go... between the welded-on washers and the hinge bar itself. Please confirm. Secondly, it is clear to me that to use the bushings, we would have to drill the hinge pin hole in the hinge bar, to a bigger diameter than would be needed for just the hinge pin without the bushing. This wider diameter being only to the depth of the bushing itself. Am I seeing htis correctly? Do others use the bushings? Thanks in advance for your guidance on this matter.
1952 Chevy 3100
Re: Restoring Door Hinges - 1952 3100
Gib70 #1406882 Tue Apr 20 2021 09:30 PM
That should work; when I've done mine on my 49 (and on other vehicles) I set it up so that the lower bushing was reversed from your picture, installed in the lower part of the "outside" piece. I have some done like that with a couple hundred thousand miles on them so it worked. But at the end of the day, what's important is that the pin is overall snug and the "rims" of the bushings are sandwiched between the two pieces of the hinge. Different ways to reach the same result.
1949 Chevrolet 3/4 Ton - Still Solid.
Gib70 #1406884 Tue Apr 20 2021 09:44 PM
I've never used bushings in these and I've not had trouble.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Gib70 #1406888 Tue Apr 20 2021 10:03 PM
AD Addict
Have you tried the pins in the hinge? You should be able to assemble it partially to check. Maybe you won’t need them as in Jon G’s case.
Maybe they include the bushings in case the hinges are worn to the point the new pins are too sloppy.
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Gib70 #1406908 Tue Apr 20 2021 11:21 PM
In all the cases I've seen the replacement pins will be a slightly larger diameter and when you drill the hinge bar to that diameter you will be left with a nice new and round hole that will accept your new pin just right. The welded-on washers will probably have worn to the point your hinge bar isn't tight anymore. You can fix this three ways. One (not my choice), put the hinge in a large vise and squeeze it carefully to compress it so that the hinge bar just slides in. Two (my choice by far), get some washers and file them down so that they fit the gap which is there. Or you might find thin washers but only at a hardware store. You won't find anything like this at Home Depot or Lowes. I try to put one on top and one on bottom. Last hinges I rebuilt the welded on washers had come off on two of the four and I just made some new (and thicker ones) and welded them on instead. Three, if you really enjoy welding, then build up the top and bottom of the hinge bar and then file it off to fit your hinge...another that isn't my favorite choice, but there are many ways to skin a unicorn. Yes, to use those bushings, you will have to use a chucking reamer to widen the hole to accept them. But please consider this: when you do that, you'll have to weld and re-drill the hinge if you ever have to work on it again (or find bushings that match those exactly or machine new bushings) and the bushings are a lot softer than the metal of the hinge. Honestly I don't know why they sell them. The 1952 hinges didn't have any bushings when they were made and since the hinge design is such that the entire bar rotates around that pin, they're sort of un-necessary. Good luck!
Jon
Gib70 #1406937 Wed Apr 21 2021 02:34 AM
I am not sure, but I believe that those hinge repair kits are for both A-D and Taskforce trucks. The bushings are needed for the Taskforce hinges, but may be handy to use on an extremely worn A-D hinge.
Gib70 #1406942 Wed Apr 21 2021 02:46 AM
They're still used on my '98 C3500.
Gib70 #1407003 Wed Apr 21 2021 09:51 PM
Luckily for me I did not have a lot of slop in my hinges on the 52 panel. I drilled the holes to accommodate the new pins and they worked well for many years.
My memory is getting bad but doesn't those hinge straps have a hole where you could squirt some lubricant in them? I sold my panel and can't go look but seems i remember the holes. I had thought about drilling them out and put a grease zerk in the hole or use a lubricant with a straw on it and squirt some in the hole.......anyone ever try that??
But if done correctly it will last for years. It may be adviseable to put some anti seize on the pin as you install it.
Jon G, I enjoyed your post. Your spot on!
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
52 Chevy Panel [photos.app.goo.gl]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.websearch.com/share/...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
Gib70 #1407015 Thu Apr 22 2021 12:07 AM
There is a lubrication hole in the hinges, but they probably never got oiled (and the oil can't really get to the upper part of the hinge. The pins tend to seize in the bar and start turning in the outer part, wearing that out. That's the way mine were anyway. I had to get medieval on one or two of them to get the pins out.
A grease zerk is a great idea. thumbs_up
I may have to look into that. I'm not sure there's enough room to clear the hinge body, but I'll definitely check. I still haven't put mine back together yet.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Gib70 #1407016 Thu Apr 22 2021 12:18 AM
Thanks! Yes, they do have a hole into which a grease zerk could be threaded if you drilled & tapped. But...my experience has been a lubricant like Lubriplate will last nearly forever and the bonus is in hot weather Lubriplate won't spread and make the hinge area look like you just fried hamburgers on it. Here is a link: https://tinyurl.com/4we5z2cx This is good up to about 175 degrees F and then after 180 F you'll be flirting with the drop point. Some of the new high temp wheel bearing greases would be ok to use on these, I think. Or mix Lubriplate with powdered graphite and that should be slippery for a long time. The problem with squirting oil in that hole is it doesn't migrate to the top of the hinge pin but it does drop down into your body.
Jon
Page 1 of 2 1 2
Moderated by  HandyAndy, klhansen
