The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (55shaker, FAST55, coilover, Johnny N, 593ETow, Hotrod Lincoln), 273 guests, and 3 robots.
Forums60
Topics123,449
Posts996,245
Members44,670
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Top Cowl Vent Repair
#1406786 Tue Apr 20 2021 04:37 AM
Happy Spring!
Washing Ole Red up after the winter and determined that the top cowl vent was leaking; I have a new gasket so figured I'd go ahead and replace it.
Unsurprisingly, there was some rust all the way around the sealing flange, and found a couple in the top (spot welds that were sitting on the rotten gasket).
That all went well, but the new gasket seems to thick? It's very firm as well, and having to apply enough pressure to get it to where it is, causes the adjustment to move. I'm wondering about making a gasket out of rubberized cork or some softer neoprene material? I even set it overnight with two 25 lb bags of #8 shot and a carton of .38/.357 LSWC on it (a good 75 pounds). Didn't even dent the gasket. Perhaps Vaseline might soften it?
Edit: I'll take a look again tomorrow, it occurs to me that the gasket might just need to be chamfered. The lip is sitting on top but really, it should "capture"the seal.
At any rate, some photos of the progress. It's a "driving project" so forgive the appearance.
I should add, I LOVE the look of these cowl vents, always have; and inside I LOVE having levers to throw. So I'm not electrifying it.
1949 Chevrolet 3/4 Ton - Still Solid.
Re: Top Cowl Vent Repair
NorthCoast3800 #1406787 Tue Apr 20 2021 06:17 AM
Where did the new gasket come from? I see some vendors have two styles, original foam and molded rubber.
I don't think vaseline will do anything to soften the rubber.
Let us know how your efforts go.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
klhansen #1406839 Tue Apr 20 2021 04:35 PM
Thank you sir; it's a Precision brand gasket definitely molded rubber. It fits the channel perfectly. I agree re: the Vaseline option. Tonight after work I'll pull the vent again and chamfer the outer top edges of that gasket - I bet that will solve it. Will report back.
NorthCoast3800 #1406887 Tue Apr 20 2021 09:55 PM
Please don't use Vaseline on rubber, neoprene or similar products. Vaseline will ruin these products and it will begin almost immediately. The original seal was a molded rubber labyrinth design and was very creatively made so it drained (to prevent the vent from sitting in water and rusting. If you have a simple stamped cut foam seal, it will lack any possible draining scheme and you'll get rust around the perimeter of your vent. If you don't have the rather firm labyrinth design, please keep looking. You do know you have to adjust the cowl vent after you remove it, yes? Also the molded labyrinth type has an upper side and a lower side. The one I recently replaced came from The Filling Station and fit perfectly.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Jon G #1406889 Tue Apr 20 2021 10:04 PM
Thanks Jon; no I won't be using Vaseline just a passing thought.
This one is a firm (hard) neoprene seal that is identical from side to side (so flip it over, it doesn't matter). Flat as a board as well. I've adjusted the cowl vent, the seal itself simply has a wider footprint than the cowl vent itself. I'm going to try chamfering the edges so that the vent itself can "grab" the seal and slide over it. Otherwise, there's no physical way this seal will work. Like I say, it's so firm that the vertical adjustment is forced out when I try and compress the seal by closing the vent. Which is obviously wrong.
NorthCoast3800 #1406892 Tue Apr 20 2021 10:18 PM
AD Addict
I looked at the seals available from the Filling station and one is made by Steele Rubber. It doesn‘t say if its a labyrinth seal or not. Is that the one you used?
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
NorthCoast3800 #1406900 Tue Apr 20 2021 10:52 PM
Yes, as I recall Steele made the one I got. It was expensive...I want to say maybe $35 or so? Several years ago I also bought one from a place called ChevyDuty and it was the right molded design. I have no idea who made it, but it worked fine. This would have been in the 80s.
If you have a hard and flat piece of rubber, I can pretty well promise that will be difficult, although the hard flat part might cause it to harbor water a bit less.
Jon
NorthCoast3800 #1406903 Tue Apr 20 2021 11:04 PM
Interesting... pretty sure this one cost about the same (in USD) so that part's not an issue. Yup just hard and flat, no flexibility or pliability at all (vertically that is). If that's the case I'll get this one functional for now but go looking for the Steele Rubber one right away.
Thanks both!
NorthCoast3800 #1406910 Tue Apr 20 2021 11:37 PM
Hard and flat sounds like it was made from solid neoprene or some other rubber compound with a shore durometer value about the same as a tire. That seal ought to have a slightly firm but compressible nature...a hardness between your door seals and vent window seals.
Jon
NorthCoast3800 #1406912 Tue Apr 20 2021 11:47 PM
AD Addict
It’s selling for $43.99 plus shipping. Sounds like it worth the extra cost!
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Page 1 of 2 1 2
Moderated by  HandyAndy, klhansen
