The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (Hotrod Lincoln, DavidBraley, 55shaker, FAST55, Gone, Jon G, 1 invisible), 277 guests, and 3 robots.
Forums60
Topics123,448
Posts996,244
Members44,670
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Rocker order
ndkid275 #1406739 Tue Apr 20 2021 12:41 AM
The grooves are centered and the oil tube is not plugged.
I do have a 261 head with a plugged oil tube. Should I use parts from that?
Chris
Re: Rocker order
ndkid275 #1406747 Tue Apr 20 2021 01:04 AM
AD Addict
You have pre ‘59 rocker assembly and it won’t work without an installed orifice. Pre ‘68 Dave shows how he made and installed this orifice in his article on his website.
I would definitely look at your 261 rocker assembly to see if it has the offset rockers. If it does and there in good shape, I would use them and the closed oil supply tube.
If they have a bit of slop (rocker to shaft) you can buy new shafts.I bought a used rocker assembly (59-62) from eBay and they had quite a bit of slop. The wear was mostly on the shafts so I bought new shafts also from eBay and that tighten things up nicely.
You could even try the rocker shafts from the 848 head. The shafts fit from 41 thru 62. Only the rockers and oil supply tube changed thru the years.
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Re: Rocker order
ndkid275 #1406753 Tue Apr 20 2021 01:30 AM
I have new shafts that I was going to use so if the rockers are good, which they should be, I’ll use them then along with the closed oil supply tube.
Re: Rocker order
ndkid275 #1406811 Tue Apr 20 2021 01:13 PM
AD Addict
thumbs_up Let us know the outcome!
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Re: Rocker order
ndkid275 #1406894 Tue Apr 20 2021 10:28 PM
Of course!
Page 2 of 2 1 2
Moderated by  Woogeroo
