The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Time to gathering together!
Fall Happenings
Since we put up promos last two weeks, we have had a bunch of activity in
The Side Lot.
See what's happening with a Stovebolt Collective near you
THE SIDE LOT
From Coast to Coast and some International gatherings listed, too.
Next up: too many to list!
THE SIDE LOT.
Go see!
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (Southerntruck, D B Cooper, DaveV, Wheelie, WE b OLD, 1 invisible), 87 guests, and 4 robots.
Forums60
Topics129,208
Posts1,047,827
Members46,222
Most Online1,229
Jan 21st, 2020
#1406616 Mon Apr 19 2021 12:49 AM
We removed the rear doors on my kid's '52 panel today. There's a bit of play in one pin otherwise the hinges dont seem too bad. Can new pins be pressed in after the old ones are pressed out? Are the pins special? Anyone have dimensions for the pins? Any other tips appreciated. Thanks.
It's a small world, but I wouldn't want to paint it.
AD Addict
Chev’s of the 40’s carry these repair kits, although not in stock at this time. They do have the dimensions listed. Here is the link. https://www.chevsofthe40s.com/detai...in_With_Bushings_Back_Door_Suburban.html
Phil
Moderator, The Engine Shop & Interiors
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery Forum
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Thanks, Phil. I contacted Chevs of the 40s and they don't think they wil ever get them in as "no one's making them now." I may check out Doorman and see if I can match the dimensions
I
Moderated
You can try the Filling Station, looks like they might have what you need.
door hinge parts [store.fillingstation.com]https://store.fillingstation.com/sh...Truck&search=hinge&searchtype=FT
I had to rebuild my barn door hinges and had to re drill the holes on the drill press. I had to go a little oversized and ended "up using hinge pins for a dodge. I used 23/64' diameter hinge pins and cut them down to 2 11/16" long, beveling the end I cut off like original. The ribs at the top of the pin need to be at least 3/8" long and no more than 7/16" long.
"A house is built with boards and beams,a home is built with love and dreams"
Look deep before you leep !!!
"Everything is Everything"
"If I say a mouse can pull a house,Hitch him up"
My 1951 3100 Chevrolet
My 1951 Chevrolet Suburban Carryall
