The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (fixite7, dunfire, John Dlugos, campbell45, 2 invisible), 217 guests, and 3 robots.
Forums60
Topics122,988
Posts992,414
Members44,581
Most Online1,229
Jan 21st, 2020
Image Posting Policy
3.90 Ring and Pinion Gears needed
#1406401 Sat Apr 17 2021 01:01 PM
Wheelie Offline OP
Looking for a good set of 3.90 gears for my 1958 1/2 ton axle.
Steve
Re: 3.90 Ring and Pinion Gears needed
Wheelie #1406446 Sat Apr 17 2021 07:11 PM
Haunting the SBP since 2001
As long as you are gonna switch out the gears....now is a good time to upgrade to the 3.38 highway gears.
Wheelie #1406465 Sun Apr 18 2021 12:10 AM
Wheelie Offline OP
I have 3.38's, don't care for them. When I make the swap, they will be available here on "The Bolt".
Steve
Wheelie #1406585 Sun Apr 18 2021 08:26 PM
PM sent
Wheelie #1406592 Sun Apr 18 2021 09:40 PM
Steve
What size/year engine, Steve?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Wheelie #1406595 Sun Apr 18 2021 10:14 PM
Wheelie Offline OP
Hi Tim,
1956 235 with a 1983 T-5 and a 1958 axle in a 1946 that I use like a truck. The T5 has the 3.50 first and .78 overdrive so it's not awful if it was just a cruise around vehicle but I'd like a bit more tug for when it's loaded with firewood or mulch or whatever else the wife comes up with for me to do in my "free" time.
Steve
Wheelie #1406705 Mon Apr 19 2021 08:10 PM
As an option, you could get a new carrier for the new gears, then just swap the 3rd member when you need the lower gears, switch back when you need to run it on the freeway.
I am considering that option for my '62.
I had 3.90:1 gears in it stock, but swapped in 3.38:1 when I rebuilt the rear end 3 years ago.
I agree that there isn't as much low end grunt as when I had the 3.90:1 gears back there. Granny gear still helps, but it's not the same going into 3rd or 4th.
I still have my 3.90:1, but they are worn beyond what I would want to run again. I am going to look for a limited slip carrier before I do a second gear set though.
Good Luck!
Moderated by  John Milliman
