The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (klhansen, 1933GMC, 1 invisible), 143 guests, and 3 robots.
Forums58
Topics122,604
Posts989,107
Members44,491
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 3 of 3 1 2 3
Re: 1950 3100 How to remove the hood
ChevyDarren #1405241 Thu Apr 08 2021 06:11 PM
You're right Phil, in that the rivets are hollow, but only thru the stationary part of the hinge. I was referring to where the arms rotate on the stationary shoulder of the rivets. Wear there can't be fixed by your method.
Your method will definitely work if the rivets are loose on the stationary part of the hinge. I've done something similar to tighten tubular rivets.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
klhansen #1405263 Fri Apr 09 2021 12:01 AM
AD Addict
I understand! thumbs_up
Fortunately, the riveting portion of the pin, was the only part loose on my hinges. I did however make oversize bushings to take up the slop in the bolts.
And I agree, if the shoulder portion of the pin is worn, the only way to fix them would be to fabricate new oversize rivets and ream out the holes.
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
ChevyDarren #1406172 Thu Apr 15 2021 12:50 PM
I’ve tried looking for that thread where someone had the tip to drill small holes through the hinges in order to help line everup when the hood is reinstalled. He said you would simply put a small pin in the hole and it would be back exactly where it was when you removed it. Can anyone find that post?
Chuck
1950 Chevy 1/2 ton (original)
1941 Chevy coupe
1938 Chevy coupe streetrod
ChevyDarren #1406180 Thu Apr 15 2021 01:30 PM
AD Addict
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Page 3 of 3 1 2 3
Moderated by  HandyAndy, klhansen
