The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (Chip O, KEVINSKI, Dusty53, Hotrod Lincoln, carbking, 1 invisible), 100 guests, and 2 robots.
Forums60
Topics125,498
Posts1,013,363
Members45,248
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Well the hydraulics work, sort of.
#1404128 Thu Apr 01 2021 12:13 AM
James S Offline OP
52 GMC 9430 Canadian 1 Ton
I managed to get the hydraulic to lift about 4 feet. Blew fluid all over the place. There is definitely water in the hydraulics. The cylinders looks like my leg did when I fell of my motorcycle (lots of road rash). Anyone have suggestions on how to repair this? Otherwise I plan on alot of fine sanding, new seals (if I can find them) and new fluid (when I figure out what I should use). It is a ROBIN hydraulic system from Calgary (according to the name cast in all the parts).
James S
Re: Well the hydraulics work, sort of.
James S #1404158 Thu Apr 01 2021 02:58 AM
A good hydraulic shop should be able to find seals. If there's a shop in your area that re-chromes rams it might not hurt getting a price.
Thorens #1404347 Fri Apr 02 2021 02:44 AM
James S Offline OP
Well I have started dissassembling the cylinders. Anyone know where I can get a 5" wrench to take of the top of the cylinder for the hoist? I have the small and medium rams out, but the large ram is still stuck in the cylinder. Also drained the remaining hydraulic oil, it came out looking like light chocolate milk.
James S
James S #1404381 Fri Apr 02 2021 12:29 PM
Hey James,
You are venturing where few dare to go. I used a 10 weight tractor hydraulic fluid in the ram on my 1941 Hercules dumper. You may need to make your own wrench with some steel plate and a cutting torch, brute ugly but will work for a one time use like yours. McMaster-Carr may have the seals that you need. https://www.mcmaster.com/
Paul
Moderated by  Grigg
