The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Hello there ...
We have a request from "Harold46".
Curious?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (ChucknPat, Ga92009, 46truck, Chad M, Dusty53, 1 invisible), 181 guests, and 3 robots.
Forums60
Topics124,036
Posts1,001,029
Members44,820
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
83 K5 Blazer
#1398341 Mon Feb 22 2021 02:32 AM
Moderator - The Electrical Bay and Rocky Mountain Bolters
I brought this gem home today. the intention is to replace my jeep.
Issues, the drivers (electric) window doesn't work, the rear (electric) window doesn't work, There is no oil pressure gauge, Mrs. Rod is mad at me, it is rusty.
Another quality post.
Real Trucks Rattle
Re: 83 K5 Blazer
Rusty Rod #1398343 Mon Feb 22 2021 02:47 AM
Leo Offline
Nice one, what are you working on first?
Re: 83 K5 Blazer
Rusty Rod #1398358 Mon Feb 22 2021 05:42 AM
Leo, Wife is mad because I have too many vics. AND most of them have "issues". She demanded that I fix the oil leak on my 2003 Jeff Gordon Monte Carlo first.
I'll be nickel & diming the Blazer to get it road worthy (and pass a smog test). While i'm putting the Suburban back together.
Real Trucks Rattle
Re: 83 K5 Blazer
Rusty Rod #1398444 Tue Feb 23 2021 01:34 AM
Not sure about Colorado, but Pa doesn't require any inspection or smog test on anything with an Antique registration. Only requirement is age. 25 years old or older. Might be something to look into? ohwell
Re: 83 K5 Blazer
Rusty Rod #1401173 Sat Mar 13 2021 03:49 AM
Glenn's, Colorado requires a smog test back to a certain year before they are exempt. After a certain year, they require a smog test annually. If I put collector plates on it, then it gets smogged every 5 years.
This peach needs to run much better before I try to smog it. I've already replaced about 12 feet of vacuum and fuel lines. All the coolant hoses are next.
Real Trucks Rattle
Re: 83 K5 Blazer
Rusty Rod #1401212 Sat Mar 13 2021 02:54 PM
Hmmm. Interesting. I wont be moving there anytime soon. Lol.
Re: 83 K5 Blazer
Rusty Rod #1402351 Sun Mar 21 2021 03:10 PM
Interesting, a week or so after I acquired the 67 Suburban, it snowed. A week or two after the big red blazer (I didn't name it) appears in my driveway, it snowed. The 4x4 works though, even with street tires on it.
BRB slams into reverse and drive, even when the idle is normal. I heard on the internet that bad mounts will cause that?
Real Trucks Rattle
Re: 83 K5 Blazer
Rusty Rod #1402445 Mon Mar 22 2021 12:21 AM
bad motor/trans mounts could cause that, also may be that the idle is too high. It can be idle smooth but still high if the O2 sensors or mass air flow are not reading properly. somtimes just driving a bit can help if the stuff is just dusty/dirty.
EDIT: when the mounts dry up there will be play in bolts allowing the motor to rock side to side when you shift. (I don't recommend it but I have just tightened the bolts down to buy some time and reduce stress on the mount themselves but it can make the rubber decide to quit out entirely)
62' GMC Fleetside 3/4 ton 235 4-speed.
Time makes fools of us all.
Re: 83 K5 Blazer
Rusty Rod #1402446 Mon Mar 22 2021 12:38 AM
Mounts are the 1st thing id check. Oped da hood. Get in da drivers seat. Do your best to see whats going on under da hood. Put it in gear. Movement? Put it in reverse. Movement? Brake torque it when in either gear. You will see whats up that way if its a mount issue. 2nd thing, could be a ton of stuff. Carrier bearing if applicable. U joints. Rear end slop. Check mounts 1st. Go from there. Keep posting.
Re: 83 K5 Blazer
Rusty Rod #1402472 Mon Mar 22 2021 02:54 AM
I've got the tranny mounts on order. the drive shafts feel tight.
It does not slam every time either, which is strange.
Real Trucks Rattle
Page 1 of 2 1 2
Moderated by  Leo
