The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (bsarts, Bruce36 1.5, 66flea, DES57, Hotrod Lincoln, 1 invisible), 133 guests, and 3 robots.
Forums60
Topics124,655
Posts1,006,157
Members44,993
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1939 differential gear lube
#1401793 Wed Mar 17 2021 11:43 PM
rickmg Offline OP
Replaced a leaking right rear axle seal. What brand/weight gear lube should I use for a stock 1939 Chevy JD Stake Bed 3/4 ton?
Rick
Re: 1939 differential gear lube
rickmg #1401825 Thu Mar 18 2021 05:44 AM
SAE 90
rickmg #1401842 Thu Mar 18 2021 01:01 PM
AD Addict
Before you go out and buy S.A.E. 90w oil, you must find out if you rear contains hypoid gears. I have a ‘52 3100 and I use 90 weight multi-purpose gear lubricant not the 90 weight mineral oil that I use in my tranny. There is a caution in my shop manual that states “CAUTION: Straight mineral oil must not be used in Hypoid rear axles or two speed axles.”
I would suspect your’s is the same, but we need on of our “experts” to chime in.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
rickmg #1401854 Thu Mar 18 2021 02:16 PM
Bubba
1939 3/4T JD - (Commercial -3/4 Ton-3 Stake Pockets - Wheelbase 123 3/4in.)
some information on lubricants - 1940 [chevy.oldcarmanualproject.com]
I could not find 1939 information.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
rickmg #1401944 Thu Mar 18 2021 11:52 PM
On a "hypoid" axle, the pinion gear will intersect the ring gear below its centerline. If the driveshaft is below the center of the axle tubes, it's a hypoid axle.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Moderated by  SWEET
