The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (tomctomc), 105 guests, and 3 robots.
Forums60
Topics123,939
Posts1,000,194
Members44,787
Most Online1,229
Jan 21st, 2020
Image Posting Policy
V8 bell housing
#1401523 Tue Mar 16 2021 12:14 AM
I am in need of a v8 bell housing with engine mount provisions. My 235 head has bit the dust and it’s time to do a swap.
Re: V8 bell housing
Sludgeburner #1401558 Tue Mar 16 2021 03:44 AM
9
Bell housing for what year,Trans, ect., ?
Karl j Townsend
Re: V8 bell housing
Sludgeburner #1401578 Tue Mar 16 2021 09:40 AM
Sorry I was to vague. My truck is a 1951 3100. The bell housing I’m looking for is from a 58-62 truck or 55-57 bel air with a v8. I’m sure the bell housing was used in other vehicle, but those are the ones I know.
Re: V8 bell housing
Sludgeburner #1401588 Tue Mar 16 2021 01:06 PM
Are you looking for the hydraulic clutch version or mechanical one . Does the housing at as rear motor mounts as well ????
good planning is no substitute for dumb luck
Re: V8 bell housing
Sludgeburner #1401605 Tue Mar 16 2021 03:25 PM
Yes Mechanical clutch with engine mounts.
Re: V8 bell housing
Sludgeburner #1401610 Tue Mar 16 2021 03:40 PM
The truck and car bellhousings of that era have completely different mount locations. I have both available which one do you want?
The truck version is 55-59 V-8 and 63-66 V-8 and 6 cyl. It mounts to the crossmember. The car version is 55-57 V-8 car which mounts to frame horns.
Fred
Re: V8 bell housing
Sludgeburner #1401624 Tue Mar 16 2021 05:42 PM
You are probably aware of this but if your pickup has the stock crossmember it will not accept the later bellhousing. If you can find a 54 crossmember it will bolt in . Or a 54 frame
ppp
Re: V8 bell housing
Sludgeburner #1401644 Tue Mar 16 2021 09:44 PM
The stock crossmember has been modified in the past to fit the current bell housing for the 1960 235 that’s in it. I have no idea what this bell housing came out of, just that the crossmember has been modified. I can modify the crossmember again to fit either.
Re: V8 bell housing
Sludgeburner #1401754 Wed Mar 17 2021 05:05 PM
Ok I think rfs56truck has you covered ^^^^^^^^^^
ppp
Re: V8 bell housing
Sludgeburner #1401972 Fri Mar 19 2021 02:53 AM
The center hole is also different between car and truck. What transmission are you using? That will be needed so Fred can get you the correct BH for your setup.
Mike B smile
Moderated by  John Milliman
