The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Hello there ...
We have a request from "Harold46".
Curious?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (Achipmunk, destryridesagain, ChucknPat, DavidBraley, glenns towing, 2 invisible), 197 guests, and 6 robots.
Forums60
Topics124,017
Posts1,000,882
Members44,813
Most Online1,229
Jan 21st, 2020
Image Posting Policy
60's Rochester B Manual Choke
#1400686 Tue Mar 09 2021 04:16 PM
HFfarms Offline OP
Looking for a Rochester B with manual choke for an early-mid 60's truck. Engine is 292. Don't care on condition or if missing parts so long as the air horn and bowl are in good condition and not broken. I do not need a rebuilt unit, would rather buy one that not currently functioning as I will disassemble for pieces.
Re: 60's Rochester B Manual Choke
HFfarms #1400757 Tue Mar 09 2021 11:51 PM
Hello Mr H. F. Farms,
I have two Rochester carbs that came off 1959 Chev 6 cyl. Would they fit in your plans. I have both of them running a couple of years ago and have been in dry storage since. How can I tell if its what you need?.
Gary
HFfarms #1401065 Fri Mar 12 2021 02:42 AM
292 will have a different choke horn.
ppp
HFfarms #1401193 Sat Mar 13 2021 12:04 PM
Triplep - Choke horn? Do you have a picture of something like that?
HB
1966 Chevrolet K-10
Flappy Fenders
In the Stovebolt Gallery [stovebolt.com]
More pictures on Photobucket [s160.photobucket.com]
1962 Chevrolet C10
1962 Suburban
HFfarms #1401207 Sat Mar 13 2021 02:27 PM
Many times the carbs will show wear in the little bracket that holds the air cleaner rod. Here is a pic
ppp
HFfarms #1401556 Tue Mar 16 2021 03:41 AM
The 55-59 carbs which were only for 235 and 261 had a smaller circle and or collar to accept the earlier style air cleaner. Is that the photo you wanted?
ppp
HFfarms #1401579 Tue Mar 16 2021 09:47 AM
thanks. It helps.
HB
1966 Chevrolet K-10
Flappy Fenders
1962 Chevrolet C10
1962 Suburban
triplep #1401585 Tue Mar 16 2021 12:35 PM
HFfarms Offline OP
That is the issue with my latest B. The entire bracket that holds said rod has broken off of the airhorn, likely from previous owner(s) overtightening the air cleaner hold down nut. I am either going to have a Rochester B graveyard soon to continually mess with these finicky suckers, or replace it all and try and get a different carb on it.
HFfarms #1401623 Tue Mar 16 2021 05:39 PM
I will look thru what I have , I think I have one off a 250 but not sure if the venturi size is the same . I know a genuine 261 carb is different from a 261 but not sure if a 292 is different size than a 250 . These are good carbs but just a little fragile on that top air cleaner area.
ppp
Moderated by  John Milliman
