WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
21 members (66rollback, chrispy, 55 SHAKER, carbking, ChimChim123, 2ManyTrucks, 1 invisible),
165
robots. |
Key:
Admin,
Mod
Forums58
Topics122,583
Posts988,946
Members44,491
Most Online1,229 Jan 21st, 2020
 Re: Oil leak remote filter
AD Addict
When doing a hard pipe installation on anything that carries fluid or air pressure, I like to put a 360 degree "vibration loop" in each line to take stress off the flare or compression fittings. In my installation, I didn’t feel the loop was necessary as there are two bends in each line that go in different directions that would absorb any expansion/contraction and vibration and the fact that it is hard mounted to the engine. I guess we’ll see!
Phil 1952 Chevrolet 3100 Project Journals‘59 235 & hydraulic lifters “Three on the Tree” & 4:11 torque tube 12v w/ Alternator
OP
Thanks all for the tips. I think I am going to try the Hardline approach using some 5/16 nicopp I have left laying around. What degree does the tubing need to be flared to? I have a line flaring tool that used when I installed the brake and fuel lines, will that work? Thanks
AD Addict
That will work fine. Just get the fittings to match. You’ll need (4) 1/8”male pipe to 5/16” female inverted flare fittings, (4) 5/16” flare nuts and I used a 1/8” NPT street elbow on the side of the filter, so the inlet tube went straight down.
53 fivewindow I once made a screw on filter bracket out of angle iron so you could change your filter from below. Use any screw -on filter with steel lines worked good. No flex lines to leak.
