The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (fonz8261, J Lucas, 5 Window 9434, Dusty53, 2ManyTrucks, 1 invisible), 185 guests, and 3 robots.
Forums58
Topics122,581
Posts988,935
Members44,491
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Oil leak remote filter
#1400452 Mon Mar 08 2021 12:12 AM
Hi all
Got the 53 fired up today.
Noticed an oil leak from the remote filter assembly.
The engine is a 235 from a 58-62 pickup. Oil pressure is good at 30 lbs. I tried snugging the fittings down. No help. Tips.tricks?
Where can I get a replacement?
[img][img]https://i.postimg.cc/hfFwz4C5/IMG-20210307-172801154.jpg[/img] [postimg.cc][/img]
Re: Oil leak remote filter
53_fivewindow #1400455 Mon Mar 08 2021 12:21 AM
Can you be a little ore specific about the location of the leak? Canister filters are notorious for leaking at the big gasket under the cover- - - -it's prone to get misaligned, or on occasion, the cover bolt isn't tightened enough. At 30 PSI of oil pressure, there is several hundred pounds of upward thrust against the cover. You really need to tighten that nut!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
53_fivewindow #1400459 Mon Mar 08 2021 12:26 AM
The leak seems to be on the underside of the rubber hose ,in the picture. Where it goes into that T fitting. No oil coming out of the cannister at all, that I can see.
53_fivewindow #1400461 Mon Mar 08 2021 12:34 AM
Put some kine of powder (foot, baby, etc) on area after cleaning it off. Get someone to start it & shut off as soon as oil shows up.
BC
1960 Chevy C10 driver 235 T5 3.73 dana 44
1960 C60 pasture art
G.M dealer tech since 1980 & counting
53_fivewindow #1400462 Mon Mar 08 2021 12:34 AM
I'd suggest getting a new set of hoses made up at a hydraulic shop, or replacing the flex lines with metal tubing if the canister is mounted to the intake manifold like most of them are. There's really no need for flex lines- - - -it was just simpler to use them when an oil filter was added as a dealer-installed option. An old, rotted flex line can burst and empty all the engine oil in a matter of a couple of minutes. Unless you're in the habit of watching your oil pressure, the first thing some people notice is the rods knocking or the engine locking up. New lines are cheap insurance.
53_fivewindow #1400466 Mon Mar 08 2021 01:06 AM
Thanks for the replies.
The plumbing it with Hardline sounds like a great idea what diameter line would you suggest I use? Is The nicopp line okay I've used that with brake lines and found it pretty easy to work with. Thanks
53_fivewindow #1400467 Mon Mar 08 2021 01:08 AM
AD Addict
I bought replacement hoses from Classic Parts and could not get them to stop leaking. I installed ridgid Cu-Ni tubing in place of the hoses. It took me a bit of time to get the bends right but it paid off. It looks great and the best part is, it doesn’t leak.
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Phak1 #1400472 Mon Mar 08 2021 01:40 AM
Looks great!
What diameter hard line did you use?
I think that is way I'm leaning.
53_fivewindow #1400485 Mon Mar 08 2021 02:55 AM
AD Addict
I used 5/16 Cu-Ni tubing and inverted flare adaptors from NAPA. Easy to bend, easy to flare. They say you can bend it by hand but I would suggest a tubing bender. Thats how I did it and it looks clean.
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
53_fivewindow #1400504 Mon Mar 08 2021 04:36 AM
Either 1/4" or 5/16" will work. The filter standpipe has a flow restrictor hole in it that's about 1/16" in diameter, so you won't approach the flow limit of even a 1/4" OD tube. When doing a hard pipe installation on anything that carries fluid or air pressure, I like to put a 360 degree "vibration loop" in each line to take stress off the flare or compression fittings. It might be overkill, but I'm always one to err on the side of caution, and/or safety.
Page 1 of 2 1 2
Moderated by  Woogeroo
