WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Forums58
Topics122,583
Posts988,945
Members44,491
Most Online1,229 Jan 21st, 2020
 46 front/rear spring shackle sleeves
OP
is it NECESSARY to replace the shackle sleeves on the frame if the threads are good and they are fit tight? do not know if they have ever been replaced. I bought new shackles with the new springs. if the consensus is yes replace them, what is the method for removal? i was thinking thread the old pin in part way and use it like a punch and drive the old sleeve out?
As always, you time and advice is much appreciated
Big Ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
 Re: 46 front/rear spring shackle sleeves
OP
AD Addict
New springs + new shackles = new bushings! This way you know that everything is good. If they have never been replaced, they definitely have some wear.
Phil 1952 Chevrolet 3100 Project Journals‘59 235 & hydraulic lifters “Three on the Tree” & 4:11 torque tube 12v w/ Alternator
AD Addict
iif the consensus is yes replace them, what is the method for removal? One of our fellow “Bolter’s”, has a website and use’s a 5/8” threaded rod for his bushing removal tool. Here’s a link that explains his whole process. [LINK] [ chev235guy.blogspot.com]
OP
thanks Phak. that will probably work
