The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
20 members (32vsnake, Bill Trotter, 55 SHAKER, Csims, 3B, 48bigtrucks), 172 guests, and 3 robots.
Forums58
Topics122,602
Posts989,186
Members44,498
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: Newly Rebuilt 327
Hotrod Lincoln #1399997 Thu Mar 04 2021 07:42 PM
For sure coming from the breather cap.
1958 3100 Apache 327 engine
Guitplayer #1400005 Thu Mar 04 2021 08:03 PM
What kind of PCV valve setup do you have? A road draft tube only works at speeds above 20-25 MPH, and some aftermarket valve covers don't have enough baffles to prevent blowby from making its way out of a vented oil filler cap.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Hotrod Lincoln #1400092 Fri Mar 05 2021 12:29 PM
No PCV valve. Thinking about it though
Guitplayer #1400140 Fri Mar 05 2021 09:12 PM
Did you reinstall the road draft tube that goes down beside the bell housing on the driver's side? If the crankcase isn't vented in some fashion, the oil fill cap will be the only way for vapors to vent. Until the rings seat properly from several miles of actual driving under load, not just running in place, there will be a considerable amount of blowby. Don't just think about the PCV- - -do it. There used to be a kit to change over from a road tube to a PCV-- - - -I installed hundreds of them when California made everybody swap to a closed crankcase vent system back in the 1970's.
Guitplayer #1400148 Fri Mar 05 2021 10:03 PM
Curmudgeon
https://www.chevytalk.org/fusionbb/showtopic.php?tid/324558/
Sorry to interrupt the discussion. It may be nothing to worry about.
This forum mentions a 64 can have a threaded hole that "may" open up to the oil galley.
Guitplayer #1400152 Fri Mar 05 2021 10:31 PM
Ahhhhhhh....... PCV valve a must. THANKS!!!!!
Guitplayer #1400182 Sat Mar 06 2021 12:51 AM
So did you have a draft tube, like Jerry asked?
Brian
1955.2 3100 Truck
Guitplayer #1400420 Sun Mar 07 2021 07:10 PM
That I do not know.
Guitplayer #1400422 Sun Mar 07 2021 07:38 PM
It's pretty hard to ignore a piece of steel tubing over an inch in diameter hanging down beside the oil filter, or a 1 1/2inch hole in the engine block behind the intake manifold beside the distributor. There should also be a round canister under the intake about 6" long that connects to the vent hole behind the manifold.
Hotrod Lincoln #1400463 Mon Mar 08 2021 12:37 AM
Some pics would be nice, might not even be a 327. Seen many so call 327 that were later 350s.
BC
1960 Chevy C10 driver 235 T5 3.73 dana 44
1960 C60 pasture art
G.M dealer tech since 1980 & counting
Page 2 of 3 1 2 3
Moderated by  Woogeroo
