The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
20 members (55 SHAKER, Csims, Bill Trotter, D B Cooper, 3B, 48bigtrucks), 171 guests, and 3 robots.
Forums58
Topics122,602
Posts989,186
Members44,498
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 3 1 2 3
Newly Rebuilt 327
#1399868 Wed Mar 03 2021 06:44 PM
Hi, I have a newly rebuilt 327 and its smoking on one
side pipe and breather. Whitish blue smoke.
What could be going on?
1958 3100 Apache 327 engine
Re: Newly Rebuilt 327
Guitplayer #1399875 Wed Mar 03 2021 07:49 PM
What's the compression on all the cylinders? How many miles since the rebuild? Run a cylinder leakdown test to check for broken piston rings- - - -not uncommon if somebody gets a little careless during the assembly process.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Hotrod Lincoln #1399887 Wed Mar 03 2021 09:35 PM
Yes, I think a compression check. Only about 75-80 miles since. Just before the snow fell.
I got in a couple small trips
Guitplayer #1399892 Wed Mar 03 2021 10:36 PM
Guiltplayer, Totally agree on a compression check. If that's not easy for you at the moment, pull the plugs and see which ones (or one) are oiled. Won't fix anything but you'll know if it's one cylinder.
What kind of break-in procedure did you use on your first drives. I like to get in high gear pretty quick, then accelerate (wot) to 40 mph, let off, slow down to say 30, then wot to 50, coast down to 30 then wot to 60. Actual speeds used in this seating the rings process depends on the vehicle and roads. Safety first. You don't want to start accelerating at too low a speed and lug the engine, causing labor knock.
Good Luck,
RonR
1970 340 Duster
1951 Farmall Super A
Guitplayer #1399897 Wed Mar 03 2021 11:00 PM
Unless it's smoking bad enough to fog for mosquitoes, don't do anything but keep an eye on the oil level for at least 500 miles. Don't pamper the engine- - - -drive it at a wide variety of speed and load conditions. If it fouls out spark plugs or consumes a huge amount of oil, chances are you'll need to open it up and see what kind of mistakes were made during the assembly process. I got called in to consult on a fresh rebuild that refused to quit using oil several years ago, and when we were finally forced to do a teardown, I found that the engine assembler had forgotten to put the oil rings on one piston. The guy had a habit of catching a bad case of Budweiser Fever fairly frequently!
Hotrod Lincoln #1399964 Thu Mar 04 2021 02:29 PM
Hey thanks!! The engine was on a dino tester and the breakin period was gentle.
I`ll check the plugs and oil level as time goes by. Thanks Ron and Jerry!!!!!
Guitplayer #1399965 Thu Mar 04 2021 02:52 PM
You may not have gotten the rings seated. Its time to build a little heat in that motor and run the rings in a bit. Do that and see where you are at. Dont use any additives for worn rings, no snake oil, just drive the motor and get a load on it.
Mike
Guitplayer #1399967 Thu Mar 04 2021 03:41 PM
I remember finishing up the assembly of a 327 round track engine just over an hour before time trials started at the local quarter mile dirt track. The "break-in" of that engine was done by a pit crew member who sat in the car and held the throttle at 2500 RPM while we trailered the car 10 miles to the track. My driver backed the car off the trailer, hit the track and ran four laps at full throttle. It didn't smoke! We won two races that night. I'd suggest finding a different engine builder next time!
Guitplayer #1399985 Thu Mar 04 2021 06:08 PM
video ...
SHA1: 78071cbb9131a67b1039cbc1a8ddc0be92178f20
Guitplayer #1399992 Thu Mar 04 2021 07:26 PM
Maybe a leaky valve cover gasket onto the exhaust? That's about all those chrome aftermarket valve covers are good for.
Page 1 of 3 1 2 3
Moderated by  Woogeroo
