The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
18 members (AD8, 52Carl, 32vsnake, 2ManyTrucks, Bellflower, 52Beastie, 1 invisible), 141 guests, and 3 robots.
Forums58
Topics122,602
Posts989,190
Members44,498
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 3 1 2 3
what bolts can I use for replacement lug studs?
#1399883 Wed Mar 03 2021 09:11 PM
My 1957 Panel needs broken lug studs replaced on both front wheels. I'm not restoring it to original. Are there generic grade bolts that I can pick up from Home Depot or Lowe's to use as replacements?
Thanks!
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
Re: what bolts can I use for replacement lug studs?
pan3lman #1399886 Wed Mar 03 2021 09:31 PM
Sir Searchalot
It's easy but Home Depot is not the place to go. Most flaps/Napa have the studs. Probably 7/16-20. At the length you need. On the bench, press or knock out the old and install the new. Search and read 6-8 different blogs/how-to's. Use a bunch of washers and a backward lug nut to draw the stud in.
Don't listen to folks saying that method won't work. The Internet has it done with washers and backward nut on Hemmings, Autozone, and a billion other places. Millions of lug bolt changes with NO problem. Pressing them in is also a good way. Pressing them out and pressing them in, has to be done with proper, strong, backing.
Watch out for careful drivers!!!
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
You can't teach a new dog old tricks.
pan3lman #1399899 Wed Mar 03 2021 11:07 PM
If you choose to pull lug studs in with a nut, call your insurance agent and beef up your life insurance. Also add a pretty good rider to your liability policy, in case you survive the accident you cause when the wheel comes off, but it runs over a few pedestrians. People with a few brain cells to rub together use a press.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
pan3lman #1399904 Wed Mar 03 2021 11:49 PM
Sir Searchalot
This is where engineers are helpful. To calm your fears of folks with myth theories. Sometimes their "common sense" is nonsense.
pan3lman #1399905 Thu Mar 04 2021 12:25 AM
Train drivers- - - - -who would have guessed?
LOL!
pan3lman #1399907 Thu Mar 04 2021 12:41 AM
I'll add that I've broken plenty of studs using the washer method. Even with plenty of lube. ESPECIALLY with an impact. Maybe, just maybe, if done by hand wrench you'll be okay. But I have even broken heavy truck studs that way. My travel truck had one of the tool box drawers dedicated for studs and lugs just for this reason.
The preferred method is with a press. Second best is with a beater. Beat on it until you hear the tone change.
Regular bolts are a no-go. They aren't designed for wheel stud service. Studs are designed with serrations on the shank to fit snugly in their hole.
My office about 15 years ago.
pan3lman #1399913 Thu Mar 04 2021 01:20 AM
Eureka!! I can do this!!
https://youtu.be/fE49dH3_aVE
pan3lman #1399921 Thu Mar 04 2021 02:22 AM
Professional procrastinator
Youtube sure makes it look easy. My studs were swaged in and did not come out quite so easy. I would guess it was 20X more difficult to get my studs out than that youtube video showed. After removing my studs, I attempted to use that very same tool from Lisle. I still broke a stud. I had them pressed in. I think they were just a couple thousandths too big for that tool to do it smoothly. The tool worked great on another vehicle however. Be prepared for your studs to not pop out like the video. I think maybe that was staged for the filming.
1946 Chevy 3/4T panel
1947.2 GMC 1/2T panel
1948 GMC 1/2T pick-up
1947 GMC 1/2T long bed
pan3lman #1399922 Thu Mar 04 2021 02:31 AM
I learned a long time ago that it's never as easy as on TV!
I still remember doing my first (and only) A arm bushings. They needed to be pressed in, and I learned that the hard way. frown
pan3lman #1399934 Thu Mar 04 2021 04:07 AM
Sir Searchalot
The ARP studs are made of steel with 190,000 psi tensile strength. The 7/16 shank will then be about 28,000 psi tensile strength. The threads would be about 10,000 psi tensile.
First of all we were taught NEVER to jerk or hammer on a wrench to tighten a nut. Never make a series of quick cranks on a socket wrench handle while tightening. This will snap the fastener. An impact wrench does exactly that. An impact wrench is really for loosening a bolt. Some of us DO NOT have an impact wrench with an adjustable torque setting. All we know is the box in comes in says the max torque is 250 ft lbs or 1000 ft lbs!!!! If you are using an impact to tighten a nut, or in this case, installing a stud, you are rubbing too many brain cells together. Some folks who are busting their studs are riding the impact trigger until she goes flush...and beyond.
A person may not have the correct size serration diameter for an already used hole.
As I said, pressing in is a good way. Not always possible. Not always wanting to pay a shop. If it breaks try another one. The luxury here is the drum comes off for good bench access. Hammer them in if you want. Click [youtube.com]
Many actual mechanics use the draw in method on the rear and FWD.
Page 1 of 3 1 2 3
Moderated by  SWEET
