Thanks Jerry, you are correct. When I took my ash tray apart, the original paint was evident behind the handle. The rest of the front was 'painted' silver.
As we discussed, the high rib is painted silver and the low rib is painted to match the cab interior color. This applies to the radio grille, ash tray and glove compartment door. The stainless trim is above and below.
I'll send you a PM on your ash tray.
Thanks again,
EDIT: Ash tray purchased from Jerry's Chevy Parts.
