The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks. Encourage one another! Share what you've learned!
Wow, thanks lot Jon for the detailed explanation! I'm going to give it a try and will let you know. Previous owner put a modern radio, so I need to unplug these wires in order to access the gauge cables, etc...
Hello,a quick update as I waited for bad weather to get back to the truck. I took the time to take the speedometer out and the needle was pressing hard on the glass. I think that s what was making it stick. The sun has changed the shape of the needle and many craks were visible. I just went ahead and ordered a new one.
I will use your directions to clean and lightly oil the parts. Any suggestions, while I am at it, in the best way to restore the odometer numbers? They are all almost wiped out by the sun/time.
Thank you!
Please look for a recent post by me in the "interiors" section. You'll see a couple of templates for those numbers and a brief comment about making/using waterslide decals plus you'll see a speedometer in which I rescued a broken central shaft. Hope it is helpful.
I can't recall where I bought that replacement needle...think it was from The Filling Station and think it was about $10 or so. The chrome disk and needle come as a unit and you remove the old one from the hub and put the new one on and fold 3 or 4 small tabs over to hold it.
Thanks for all the help/feedback. I received the replacement today but the color is white, while the original is beige. Do you have any tips as to how to get the original color?
I think I ll go ahead and redo the gauges following your previous post. Any idea on how to restore the odometer numbers?
You could repaint the needle or you could re-do the face plate to restore the white numerals & markers. All the colors have changed with time. Yes...please look for a recent post in this same section about restoring the odometer numerals. They'll be white, though. White/black or I also posted an image for black background/white numerals.
Hi, I was wondering if there was a way to "clean" or "refurbish" the old gauges without having to put decals? For the odometer, I have no choice but to go the decal route, but what about the rest? Can it be done? With what chemicals?
