The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
20 members (dougs, 66rollback, D B Cooper, 2ManyTrucks, billinwisconsin, 55 SHAKER, 1 invisible), 148 guests, and 3 robots.
Forums58
Topics122,583
Posts988,946
Members44,491
Most Online1,229
Jan 21st, 2020
Image Posting Policy
hard start 350
#1399366 Sun Feb 28 2021 10:00 PM
1pete1 Offline OP
i have a rebuilt 1976 chevrolet 350 small block . new edelbrock 4
barrel carburetor and automatic choke electronic ignition regular horse power no custom stuff standard transmission , starts quick when the engine is cold however after after the engine is warmed up [30 minutes driving ] turn the engine off to make a quick stop at a store . it takes some hard cranking to start the engine again ? thank you 1pete1
Re: hard start 350
1pete1 #1399368 Sun Feb 28 2021 10:13 PM
Hold your gas pedal to da floor when that happens. See if that helps.
Re: hard start 350
1pete1 #1399372 Sun Feb 28 2021 10:25 PM
Sounds like percolation. Too much heat under the carburetor making the fuel hot.
Brian
1955.2 3100 Truck
Re: hard start 350
1pete1 #1399421 Mon Mar 01 2021 01:56 AM
If you can find non-ethanol gas in your area, try a tank and see if it helps. Also with a Eldebrock I'd run a spacer under the carb to help reduce the heat gain that causes percolation. Something like this. [summitracing.com]
Best of Luck
RonR
1970 340 Duster
1951 Farmall Super A
Re: hard start 350
1pete1 #1399436 Mon Mar 01 2021 03:11 AM
When you say "hard cranking" what do you mean?
If the static ignition timing is just a little too fast the starter may make a "grunting" sound while trying to crank the engine. If it does this, retard the timing just a little until it will turn over easy.
If it cranks fine but simply not firing up then could be carb is flooding the engine while it is sitting. Is there a thick gasket between the intake manifold and the base of the carb? That might help a little with heat transfer issues to the carb.
Re: hard start 350
1pete1 #1399575 Mon Mar 01 2021 09:49 PM
1pete1 Look at your timing system are advance weights sticky? initial timing set right,TDC mark in the right place,does it smoke black when it does fire-up,carb insulation might help (thick gasket),is it carboned-up,slap a double handful of ice on the fuel pump if its in the open might tell you something,starter bushings well worn can let the armerature bow enough to rub on the fields in a hard cranker,if the valve guides are alittle tight mighthurt hot starting ! Good Luck with your hunt !!
Moderated by  Woogeroo
