The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks. Encourage one another! Share what you've learned!
Hi Joe, I might have what you need but the U shaped bracket that holds the rod to the column is usually cracked and hard to find but I will see if I can get it off. Everything else should come off with some PB Blast. Gerry Lee
