The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Thanksgiving
Much to be
thankful for
YOU!
The Stovebolt Collective
Thankfulness year 'round.
All around!
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (WE b OLD), 60 guests, and 3 robots.
Forums60
Topics127,654
Posts1,046,324
Members46,391
Most Online1,229
Jan 21st, 2020
Page 3 of 3 1 2 3
ol' 55 #1399031 Fri Feb 26 2021 08:29 PM
ol' 55 Offline OP
Thanks for all the help there Bolters...….
ol' 55 #1399061 Sat Feb 27 2021 12:45 AM
Never had much luck with saginaw 4speeds. One good speed shift from first to second would usually break it
1953 Chevrolet 3100
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
1964 GMC 1000
ol' 55 #1399125 Sat Feb 27 2021 04:18 PM
They were not designed to be speed shifted from the start!
Ed
EdPruss #1399129 Sat Feb 27 2021 04:31 PM
Ed
Respectfully disagree Dragsix, about the only bad info I have seen you give. I have rebuilt many of these aluminum models and cant say anything redeeming about them, sorry. They have the lasting ability of a 16 year old boy on his first date.
Had one of these pos in my factory cosworth vega and it couldnt even take the torque of a 140 cu inch (115hp)four cylinder motor. Complete junk transmissions that one should think twice about before putting in their stove-bolt truck.
1953 Chevrolet 3100
1964 GMC 1000
ol' 55 #1399246 Sun Feb 28 2021 04:14 AM
I understand, I do, but I ran that cast iron Saginaw down the drag strip I cant tell you how many times between 2015 and 2017 behind a 261 without a single hic up. It was what I could afford at the time and it turned out to be very reliable. You just had to be easy with it. Like I said, no burn outs, slicks, big tires, dry hops, speed shifting, and other abuse. I replaced my sag in 2018 with a Muncie but my son is going to use the sag in a 57 car he is rebuilding. For an inexpensive traditional four speed it really can’t be beat $ wise. If you want to engage in abuse, it is not going to be the trans for you. But for everything else, it’s a pretty good choice if you are trying to be careful with the bread. Frankly, it was installed behind hundreds of thousands of vehicles over the years and provided dependable service, as long as it was not abused.
Mike
sstock #1399281 Sun Feb 28 2021 01:52 PM
People break t56 transmissions at less than 300hp everyday. Its pretty easy to yank it into gear and “break” it. Yet in stock form they will hold over 800ft lbs all day long. Usually its a clutch or driver issue. My saginaw 4 speed was speed shifted behind a beastly powerplant and never broke during a shift but rather when the power came on rolling into it with tons of torque in a turbo setup. If your clutch releases clean and your shifter is set up right it should have no issues. I wish my T56 shifted as good as my old sag 4 speed. I have a video on my phone of how i treated my 4 speed but i cant really post a vid on here. Mabey i will put it on YouTube and link it.
ol' 55 #1399283 Sun Feb 28 2021 02:06 PM
Here ya go. Drove it like this everyday for at least 2 years and drove it to and from drift events and ran it on the tracks all day long with no issues.
Saginaw 4 speed beat down [youtu.be]
Page 3 of 3 1 2 3
Moderated by  SWEET
