The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
20 members (32vsnake, 1955first6500, Bill Trotter, 55 SHAKER, 2 invisible), 158 guests, and 3 robots.
Forums58
Topics122,602
Posts989,186
Members44,498
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: Speedometer gauge issue
Muffin #1372829 Mon Aug 10 2020 07:48 PM
Muffin Offline OP
Wow, thanks lot Jon for the detailed explanation! I'm going to give it a try and will let you know. Previous owner put a modern radio, so I need to unplug these wires in order to access the gauge cables, etc...
Muffin #1372839 Mon Aug 10 2020 08:23 PM
Unhook the battery first if you're concerned about wiring.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Muffin #1398877 Thu Feb 25 2021 09:57 PM
Muffin Offline OP
Hello,a quick update as I waited for bad weather to get back to the truck. I took the time to take the speedometer out and the needle was pressing hard on the glass. I think that s what was making it stick. The sun has changed the shape of the needle and many craks were visible. I just went ahead and ordered a new one.
I will use your directions to clean and lightly oil the parts. Any suggestions, while I am at it, in the best way to restore the odometer numbers? They are all almost wiped out by the sun/time.
Thank you!
Muffin #1398879 Thu Feb 25 2021 10:00 PM
Muffin Offline OP
Here s a quick picture. The needle came appart as soon as I opened the glass cover... The back of the needle broke when I touched it.
Muffin #1398891 Thu Feb 25 2021 10:25 PM
Thank you!
Please look for a recent post by me in the "interiors" section. You'll see a couple of templates for those numbers and a brief comment about making/using waterslide decals plus you'll see a speedometer in which I rescued a broken central shaft. Hope it is helpful.
Jon
Jon G #1398928 Fri Feb 26 2021 12:41 AM
Muffin Offline OP
Hi Jon! Thanks for the quick reply. I ll put the link to your post for future reference:
https://www.stovebolt.com/ubbthread...52-gauge-decal-template.html#Post1398550
Wherr did you find the replacement needle? Does the chrome disk below the needle come off the shaft easy?
I burnt the wire that goes to the ammeter today, so I m in for quite some work!
Muffin #1398933 Fri Feb 26 2021 12:52 AM
I can't recall where I bought that replacement needle...think it was from The Filling Station and think it was about $10 or so. The chrome disk and needle come as a unit and you remove the old one from the hub and put the new one on and fold 3 or 4 small tabs over to hold it.
Jon
Muffin #1399603 Mon Mar 01 2021 11:46 PM
Muffin Offline OP
Hello!
Thanks for all the help/feedback. I received the replacement today but the color is white, while the original is beige. Do you have any tips as to how to get the original color?
I think I ll go ahead and redo the gauges following your previous post. Any idea on how to restore the odometer numbers?
Thank you!
Muffin #1399607 Tue Mar 02 2021 12:23 AM
You could repaint the needle or you could re-do the face plate to restore the white numerals & markers. All the colors have changed with time. Yes...please look for a recent post in this same section about restoring the odometer numerals. They'll be white, though. White/black or I also posted an image for black background/white numerals.
Jon
Muffin #1405036 Tue Apr 06 2021 10:07 PM
Muffin Offline OP
Hi, I was wondering if there was a way to "clean" or "refurbish" the old gauges without having to put decals? For the odometer, I have no choice but to go the decal route, but what about the rest? Can it be done? With what chemicals?
Page 2 of 3 1 2 3
Moderated by  ndkid275
