The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (Elmo, DennisM, CATMAN, 51chris, Greg_H, 3B), 154 guests, and 3 robots.
Forums58
Topics121,784
Posts981,732
Members44,304
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Right hand tie rod
sub57 #1398521 Tue Feb 23 2021 06:53 PM
Here is a picture of the tie rod assembly. Also found a better price for one of the tie rod ends.
!956 Gmc Napco 4x4 Factory line built .
sub57 #1398522 Tue Feb 23 2021 07:30 PM
With that offset in the rod, you'd have to remove both ends to get it spot on, although it might be possible to turn the rod with one end loose, assuming the offset would allow that. I had a '72 Chevy K10 and an '84 GMC K2500 and they both had the tie rod (without offset) in front of the axle, along with an adjusting sleeve. There looks to be enough space on the left end of the rod to cut and rethread the rod and use a sleeve. It would need to be a left hand thread to form basically a turnbuckle. Then adjusting toe-in would entail loosening the clamps on the sleeve and turning it so the ends could stay installed in the steering arms.
Sack's pic is of a Classic Industries catalog page. I have the same catalog.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
sub57 #1399064 Sat Feb 27 2021 01:23 AM
sub57 Offline OP
Received the rare parts tie rod end today ( RP26616 ) for the 1957 1/2 ton suburban NAPCO. Installed it this afternoon and it fit like a glove. Thanks for the input guys.
Page 2 of 2 1 2
