The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (Hotrod Lincoln, Harold41, 51chris, Greg_H, 3B, fixite7), 151 guests, and 3 robots.
Forums58
Topics121,784
Posts981,732
Members44,304
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 4 of 4 1 2 3 4
Re: 1966 GMC 960 from grain truck to tire truck.
BorderMechanical #1368230 Wed Jul 08 2020 05:09 PM
If you changed to Dayton's using the other truck parts, I believe you could swap the hubs and use your current housing. You would have to pull the axles to do that after which it would be simple to swap the center sections. That way you would keep your current ratio too.
Someone who knows better will correct me if the hubs cannot be swapped, but I am pretty sure they can be. My 69 T-50 has Daytons and the bearings and hub internals look very standard.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
BorderMechanical #1368252 Wed Jul 08 2020 08:17 PM
really curious to know if they can be swapped. i think someone told me the axle housing was longer on these other ones
BorderMechanical #1398278 Sun Feb 21 2021 08:28 PM
Well it may be time for an update. i found a set of the accuride 22.5 rims, with nearly new tires on a 76 c60, so that solves my 20 inch rim issues. as for my 6.5 swap i have run into an issue with the clutch. it turns out the biggest flywheel i can find is a 13 inch for the 6.5, and the smalleat clutch with my 1.5 inch 10 spline input is also 13 inch. i will have to look into getting one custom made for it. however i am really impatient so i picked up a 366 to get the truck on the road in the meantime.
BorderMechanical #1398313 Sun Feb 21 2021 11:26 PM
I hope when you picked up the 366, you had a close place to put it down.
I went to a local clutch place(Denver, CO) a few years back and they put a 1.5”, 10 spline center in a disc that was used, normally, in a smaller clutch.
Perhaps you can find a place near you who does clutches, it is not rocket science.
Ed
EdPruss #1398517 Tue Feb 23 2021 06:03 PM
that seems to be the avenue im going to have to go down, however my nearest place for something like that is 5 ish hours away. i am still planning on doing it, but will have to stick to the 366 for this year, as i need my picker for air cart tires in the spring.
do you recall roughly what they charge for making the disc?
BorderMechanical #1398575 Wed Feb 24 2021 02:49 AM
I don’t remember, but it wasn’t much. Can you just ship a new disc to you?
Ed
EdPruss #1398640 Wed Feb 24 2021 05:43 PM
That was the plan Ed. if im doing that i should just call the shop where you went, probably save me some explaining here. if i recall i had asked about it when i was looking for a pto gear from the shop up here, and they said no. which is why i was looking for a factory part number to just order one. could you pm me the name of the shop you used?
BorderMechanical #1398772 Thu Feb 25 2021 02:45 PM
That shop is no longer there, probably done 20 years ago.
Ed
Page 4 of 4 1 2 3 4
Moderated by  69Cuda, Grigg
