The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (booger, Cosmo, 2ManyTrucks, EdPruss, 3 invisible), 154 guests, and 4 robots.
Forums58
Topics121,784
Posts981,727
Members44,304
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Squeak from front brakes 55.1 3600
#1398509 Tue Feb 23 2021 04:42 PM
66flea Offline OP
I recently developed a squeak from the front brakes. It's a high pitch squeak or squeal that stops when brakes are applied and starts again. I first noticed it five miles into my ten mile drive home from work last week and its still there. I searched and learned it may be dust build up, shoes needing sanding or other things but i don't know what to look for. After some snow melts, I plan to take off drums to inspect and clean but would like to know if there is any tell tale signs to look for. Thanks, Brian
1955 First series 3600
Re: Squeak from front brakes 55.1 3600
66flea #1398570 Wed Feb 24 2021 02:22 AM
Brian does this happen all the time when no brakes are being applied? Or does it happen when turning? If yes to turning, does it happen in one or both directions? I had a 55 Olds that the previous owner repl aced every brake part on the front Brakes because they had a Squeak when turning Right but not left. I bought the Olds with the Squeak and found the that the Front Wheel had oblong hole for the lug nuts. You could never get the Wheel tight before the lug nuts bottomed out on the drum. Changed the wheel with the spare squeak gone. I would suggest jacking up the wheel that the sound is coming from and seeing if you can't locate it that way. Good Luck!
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
66flea #1398574 Wed Feb 24 2021 02:46 AM
Best bet, like you said. Take a look. We can only speculate on what may or maynot be happening. You'll know what ups when you pull da drums. If nothing is apparent, then would be da time for trickery...... secret
66flea #1398865 Thu Feb 25 2021 08:57 PM
66flea Offline OP
Brian Moore was right. When I took the hubcap off there was metal filings. I thought the holes were oblong so i took it to a local rim repair shop. They told me that they weren't oblong but rubbed raw from the wrong size lug nuts. I replaced my original split rims with ford econoline rims eight years ago and he told me ford has 9/16 studs and my truck has 1/2. So I got larger lug nuts and it solved the squeak problem. I will go around and change all the other lugs soon. Thank,Brain
Moderated by  SWEET
