The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (bandbrent, 5 Window 9434, ccanepa50, Bellflower, 2 invisible), 154 guests, and 3 robots.
Forums58
Topics122,583
Posts988,939
Members44,491
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
What fan to use?
#1398461 Tue Feb 23 2021 04:49 AM
53&Me Offline OP
I'm sure there is a write up on this somewhere that may have the answer to my question but I haven't been abke to find it. ..Sooo here is my current situation while I wait for parts to show up. I am working on getting my recently aquired 1953 chevy 3/4 ton with original 216 ci and 4 spd manual trans back on the road after its roughly 30-40 year slumber. I have been removing and inspecting various parts to give this beast it's best chances and have found that the radiator fan has a bent fin on one tip and a crack halfway through the fin near the axis. My fan measures 18" from tip to tip. The problem I am having here is where to get a replacement 18" fan, or should I just replace it with the 15.5 fan that basically all of the classic truck parts suppliers say is what I should be using?
Carter has a write up on fan blades and even some pictures of the blade I am looking for but no 18" fan for sale. According to the write up the 18" was an option with a radiator with aditional cores. Sorry for no pictures, My phone doesn't do pictures so well.
Re: What fan to use?
53&Me #1398465 Tue Feb 23 2021 10:35 AM
7
If it were mine I would use the 15.5" as a test and to make the truck drivable, then you could do some more research on the original and maybe come up with a plan to repair it.
1957 Chevrolet 5700 LCF 283 SM420 single speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto
53&Me #1398473 Tue Feb 23 2021 12:58 PM
AD Addict
You could always post in the “Truck Parts Wanted” forum.
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
53&Me #1398480 Tue Feb 23 2021 01:33 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
What Phil said!
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
53&Me #1398493 Tue Feb 23 2021 02:51 PM
I got a 15 if you decide togo that route. Pm me if so.
53&Me #1398497 Tue Feb 23 2021 03:23 PM
I bought a new old stock 18" fan blade on EBay a couple months ago. Even had the original box. It was $80 dollars but I knew it was not abused.
If you get a used one you might want to clean the blades with a wire wheel to bare metal where blades meet the hub near the edges and inspect for small cracks. (Just for piece of mind)
I know that 2 blade Model A fan blades were prone to fatigue cracks near the hub.
1951 Chevy 1/2 ton
53&Me #1398498 Tue Feb 23 2021 03:43 PM
Shop Clutterist
Gord
1954 1/2 ton 235 4 speed
53&Me #1398500 Tue Feb 23 2021 04:09 PM
I had one of those nylon fans on my 55 Chevy. They do move a lot of air.
Brian
1955.2 3100 Truck
53&Me #1398559 Wed Feb 24 2021 12:07 AM
The amount of air move is proportionate to the diameter of the blades, squared. A larger fan can be run at lower speed by changing pulley sizes to save gas, reduce noise etc.
The opposite (a small fan turning faster) uses engine power at a higher rate for the same air volume: the fan RPM, cubed.
53&Me #1398602 Wed Feb 24 2021 08:52 AM
53&Me Offline OP
So good news.....maybe, I have found an old classic car yard near me sp I woll be headed out there yo hopefully find a fan that will either get me by of just solve my problem all together. O'll let you guys know what I find....or don't find. I will be looking for something to keep the stock appearance so a metal fan for sure.
Page 1 of 2 1 2
Moderated by  Woogeroo
