The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (homer52, lumbersawyer, Harold41, dands, D B Cooper, 2 invisible), 136 guests, and 6 robots.
Forums60
Topics124,729
Posts1,006,726
Members45,019
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Dash pad replacement
#1398335 Mon Feb 22 2021 01:41 AM
Moderated
I have a 1986 GMC that needs a new dash pad. Has anyone replaced their dash pad recently? If so, where did you buy the replacement pad that you used and how satisfied are you with the results? Also, what is the level of difficulty with doing this with the windshield in place? Thanks!
Re: Dash pad replacement
ShannonH #1398434 Tue Feb 23 2021 12:16 AM
TGP Offline
LMC truck or any of the reputable vendors of this era truck parts will have
A decent pad.
If you have one of the common interior colors you can order the pad colored.
Otherwise your going to have to paint it.
The glass does not need to come out.
You remove the gauge cover by removing the screws surrounding it
And the lower cover around the steering column.
Then the screws at the bottom of the cover along the dash paint line
Lift up front of cover and pull toward you and that will release the clips at the bottom of the glass.
I'm sure there's probably a U-Tube video out there.
Good Luck,
Tom
TGP #1398450 Tue Feb 23 2021 03:35 AM
Moderated
Tom, thanks for the info. Have you used one of the LMC dash pads? So installing the replacement would just be a matter of getting the clips lined up properly and then popping the pad into place? I couldn't tell exactly how it is retained by looking at it so your description is a big help.
ShannonH #1398506 Tue Feb 23 2021 04:33 PM
TGP Offline
Yes I have but many years ago.
I'm sure there still good.
Also they make slip over covers that are not bad.
Sometimes that works well.
Forgot to mention there is a screw on the side at
Each end of the pad.
You start the clips in place then reinstall all the screws.
Tom
ShannonH #1415306 Tue Jun 29 2021 04:00 PM
7
dash pads are very easy to replace and do not require removing the windshield. I would suggest USA 1 Industries, https://www.usa1industries.com/ they have great products.
1952 Dodge M-37
1956 Chevy 3600 Napco
1974 Chevy K20
ShannonH #1419481 Thu Aug 05 2021 02:57 AM
How did it go? Have you successfully replace the dash pad on your car?
Moderated by  Leo
