The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy Birthday U S A !
Celebrating
Life, Liberty
and the
Persuit of Happiness
Happy Birthday
A M E R I C A
July 4 - 246 years
Stories, Pictures, Thoughts
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (3B, Evan Krueger, coilover, Gooberdog, 55shaker, 2 invisible), 116 guests, and 3 robots.
Forums59
Topics128,081
Posts1,037,106
Members45,928
Most Online1,229
Jan 21st, 2020
#1397174 Sun Feb 14 2021 12:36 AM
Looking to get a 283 rebuilt for a truck project, any recommendations for a shop in NC or VA are appreciated.
Slick Willy #1397181 Sun Feb 14 2021 01:05 AM
There's nothing particulatry mysterious about a 283, other than the fact that the newest ones are over 50 years old, and finding one that hasn't been rebuilt a couple of times already is going to be difficult. Are you looking for a "numbers-correct" restoration, or just a reliable daily driver? Finding a set of 58 CC combustion chamber 305 cylinder heads from the late 1970's or early 80's will be a lot simpler than locating rebuildable 283 heads, and they're a bolt-on swap that will give you the correct compression ratio.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
Hotrod Lincoln #1397186 Sun Feb 14 2021 01:32 AM
Thanks for the reply. Definitely not a correct restoration, this will be going in a 52 International L132 to make it a driver. Will likely pair it with a sm465 and a 14 bolt rear end.
Slick Willy #1397189 Sun Feb 14 2021 01:59 AM
I'd suggest finding a 305, then. It's got 1/2" more stroke, and a lot more torque than a 283. The only way to do truck stuff with a 283 is to run a very low gear ratio and keep it wound up all the time. There's also a bunch more 305's out there than 283's, and if you happen to have a correct engine number for a restorer to use, your engine will be worth a big chunk of pocket change, regardless of what condirion it's in at the moment.
Kris Kristofferson
Slick Willy #1397201 Sun Feb 14 2021 03:00 AM
Moderator - The Electrical Bay and Rocky Mountain Bolters
Have you considered an LS swap? rather than an old sbc?
Another quality post.
Real Trucks Rattle
Slick Willy #1397202 Sun Feb 14 2021 03:03 AM
What about a 345 or 392 and 5 speed?
Ed
Rusty Rod #1397204 Sun Feb 14 2021 03:12 AM
I already have the 283 and it does run and I know it won't be a powerhouse. My thoughts were if I don't use the 283 then I'd go with a 350 or a 383 stroker. How does the cost of the LS swap compare to the sbc? What manual trans would work? This truck will be hauling 2-3 tons.
EdPruss #1397205 Sun Feb 14 2021 03:15 AM
Ed, are you talking about an international motor and trans? I would certainly consider it if I had access to that combo.
Slick Willy #1397206 Sun Feb 14 2021 03:17 AM
If you do decide to use the 283, I'd suggest a few more gears- - - -like maybe a 2 speed rear end, or a Brownie. As I mentioned before, a lugged-down short stroke engine won't get out of its own way. I'd suggest a big block Chevy for doing some serious freight hauling- - - -a 427 or 454. You can find some low mileage big blocks in retired motorhomes.
Kris Kristofferson
Moderated by  Woogeroo
