The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (gswbbc, Bruce36 1.5, 3B, Johnny N, Capt Oblivious, 1 invisible), 113 guests, and 3 robots.
Forums60
Topics124,653
Posts1,006,150
Members44,993
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Steering Wheel Help?
#1396304 Mon Feb 08 2021 02:07 AM
Hi All,
Mine has some cracks .. is there anything I can use to fill or seal them WITHOUT pulling the it? Looks pretty difficult to do but .. why pull it if I don't have to.. Either way, any suggestions on semi-restoring; sealing the cracks and protecting it from the elements?
'38 1.5ton; "The stuff is as tough as woodpecker lips"
Re: Steering Wheel Help?
38_1.5Ton #1396360 Mon Feb 08 2021 12:51 PM
I found this a while back. Maybe it will help.
1949 5 Window 3100
Veteran of the USAF
https://zippi6.wixsite.com/adtruck
38_1.5Ton #1396388 Mon Feb 08 2021 04:10 PM
Thanks. I found some product online as well. Just wanted to see what the latest and greatest was and any more insight.
38_1.5Ton #1396717 Thu Feb 11 2021 01:56 AM
Pulling steering wheels is pretty easy. At least most of the time it is.......
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
38_1.5Ton #1396720 Thu Feb 11 2021 02:45 AM
Rent a steering wheel puller from your local auto parts store.
38_1.5Ton #1396723 Thu Feb 11 2021 03:02 AM
I just used Kwick weld j b weld that I had leftover worked good for my extra steering wheel ,I used a 1/16 drill bit to clean out the cracked area .
kevinski 1954 GMC 9300 Welcome to the virtual Garage [stovebolt.com]
38_1.5Ton #1396859 Fri Feb 12 2021 12:40 AM
38 1.5 ton wheel is easy to pull,make a simple puller out of flat steel and bolts,or take a hacksaw blade to the cracks with it on the truck. Saw in there then fill,file and sand till its good enough,then paint. Use JB weld to fill.
38_1.5Ton #1396861 Fri Feb 12 2021 12:48 AM
I used PC-7 heavy duty 2-part epoxy on my steering wheel and it worked very well. It does not shrink and files/sands well.
Charlie
'51 3100 5-Window (Restomod in progress)
38_1.5Ton #1396868 Fri Feb 12 2021 01:32 AM
Bubba
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
38_1.5Ton #1396871 Fri Feb 12 2021 01:53 AM
Thanks guys. smile
Page 1 of 2 1 2
Moderated by  ndkid275
