Remember
The old Bulletin Board?
click to enter
The old Bulletin Board has been removed from the server. And with recent "spring" cleaning, we are removing links back to it. The BB is still out in cyber space (to some extent) thanks toThe Wayback Machine.
Oh Lord, I just gotta find it... .
Forums59
Topics128,095
Posts1,037,207
Members45,931
Most Online1,229Jan 21st, 2020
OP
Is there any problems with putting 50 doors on 54 cab. Truck is 54 3100 5 window. Any problems with striker or latch location?
AD Addict
The strikers are different on the 50 so changing them to the 50 style would be necessary. I don’t know if there’s any other mods you would need to do.
You shouldn't have an issue I used 49 doors on my 54 cab. However I used Altman Easy Latches so I could put electric locks in it.
1951/54 Basketcase
Or, if you want to use “original” latch/catch, use a pair from the same year/style. There were at least two different styles between 47-55st.
AD Addict
First photo, 47-51 latch. Second photo, 51-55 1st series latches (also fit 55 second series thru 62).
Another option is to use a Hagan vent window elimination kit on your 51 and up doors.
Evan
The recess in the cab is different where the strikers go I've never had a set close properly when mixing and matching. I was able to put 54 doors on a 48 but not the other way around. Altman or Bear Claw probably fixes that.
