The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (47 BOMBER, 66flea, Darling, Ausfahrt, Hambone, 1 invisible), 101 guests, and 3 robots.
Forums60
Topics127,472
Posts1,031,731
Members45,787
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 6 of 7 1 2 3 4 5 6 7
Re: 1951 3100 pickup
chrispy #1431212 Wed Nov 24 2021 05:46 PM
chrispy Offline OP
Luckily, we didn't wind up with Lucas wiring! Better known as Prince of Darkness. Lots of funny jokes about Lucas electronics and its the reason the Brits still drink warm beer! LOL.
I have a 54 235 core motor and am doing some measuring on the length. Both 32" with the jag engine bing maybe a 1/2 shorter. Both had starters on the passenger side, exhaust on the drivers side. Other than carburetion, it seems like an easy fit. Mating a T-5 trans could get a bit tricky, but there is a great YouTube channel (macro machines) who's adapted an original flathead clutch/bellhousing to a jag engine he's fitting to a scratch built indy racer. Super talented kid.
These are all future plans. Right now the 216 knocks. Will try and scrape/adjust/measure rods. If too bad, I'll dive into the 235. It happens to be a 54 Truck solid lifter motor. May be my winter project. We took it out of my dads 51 and replaced with a 60 235 that was a fresh build, he found cheap.
chrispy #1431227 Wed Nov 24 2021 07:37 PM
Mixed Up
Chris, where are you in Missouri? I don't think I have met you yet?
What did Lucas make that didn't suck?------------------------------------------------------Vacuum Cleaners!!!
Don
"The Flag Pole"
In the Stovebolt Gallery [stovebolt.com]
More pix on Photobucket [s893.photobucket.com]
'46 2-Ton grain truck
'48 3/4-ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
'70 American LaFrance pumper fire truck.
chrispy #1431244 Wed Nov 24 2021 09:18 PM
chrispy Offline OP
Holden, just east of Kansas City.
chrispy #1431584 Sat Nov 27 2021 11:00 PM
chrispy Offline OP
So, pulled out a 1954 235 my dad gave me. Serial # says .......F54X. Can't seem to find what the X stands for, but I think truck, solid lifter. Anyways, found an interesting surprise of a standard bore block, 3.5665 with a pair of calipers. (3.5625 stock). So a little wear. Dropped out #5 piston, which came out surprising easy!? Decided to take a ring off and reset in the bore to see what it looked like. Holy cow, it looked a little big. Like .080"! Wow, allot of ware, but didn't really make since. Talked it over with my car buddies over lunch, figuring I'd have to do an overbore and new pistons, cam/lifters look wasted also. But .080" just didn't add up. I can slide the 2nd ring right into the gap just to verify.
After some discussion with my car buddies, I looked up the 216 bore size. 3.500" even. Bingo, adds up now. 216 rings in a 235 will have a .0625 ring gap to start. Explains all the oil in the combustion chamber and not allot of ware on the cylinder walls (low tension). We never ran this motor long, as we got a later, fresh 235 for cheap, so didn't take time to inspect this one.
Looks like I will be able to just do a ring/bearing job, along with a hydraulic cam. The new mechanical cam/lifters are quite a bit more money over hydraulic.
chrispy #1431777 Tue Nov 30 2021 02:40 AM
The F54X is, as you guessed, was originally designated for truck service. A '54 235, manufactured in the Flint, MI plant. So here's the thing. Through '55, the 235 blocks that came from the factory with solid lifter cams did not have the oil gallery drilled to support hydraulic lifters (all '56 and up blocks do have that oil gallery drilled, regardless of original service, but not the earlier blocks). Unless you find a machine shop that can affordably "rifle" drill that gallery, it's solid lifter camshaft and lifters, only, in that block.
But really, the options aren't all that expensive. A nice upgrade is the Elgin E-293-S cam, which is ground on new blanks to the 261 truck engine spec. It's the same cam grind that was used in the '53-'54 Corvette 235s, so slightly higher lift and longer duration than the 235 cams. Combine that with the truck aluminum timing gear and Melling JB-874 (or Sealed Power AT-874) lifters, and that's a very nice combination. The Elgin cam is available online for around $120, last I looked. HRL Jerry recommends a similar cam from another company, that's also an option... foggy memory on the details.
Hope that helps!
Doug
drdoug #1431875 Tue Nov 30 2021 10:34 PM
chrispy Offline OP
Thanks Doug.
Very helpful indeed! Much appreciated!
I prefer the solid lifters anyway. I've got rings/bearings coming, so will order lifters and check out the Elgin cam you mentioned. My dad said he had the old cam out of his 235, which is also a solid cam, so will look over the condition on that as well.
chrispy #1442850 Sun Feb 27 2022 06:07 PM
chrispy Offline OP
Well, not allot of stuff accomplished over winter like I hoped. Putting together a new 235 thats still at the machine shop. Lucked out on going .040 over. Fully rebuilt head, Schneider reground cam waiting to show up. In the mean time, I do have all new glass/seals installed and some welting installed. Most of the wiring laid out. Waiting on a back ordered clip thats riveted to the headlight canister, as one is broken.
chrispy #1442895 Sun Feb 27 2022 11:26 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Posting photos of cars?
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
chrispy #1442920 Mon Feb 28 2022 02:09 AM
chrispy Offline OP
Relax, I promise you, they won't bite.
chrispy #1442923 Mon Feb 28 2022 03:03 AM
Just against our policy.
Moderated by  HandyAndy
